Zendrix
Wall End - cut outline error
Hi!
Im having an issue with a wall end in a simple composite wall made of plaster/brick/plaster. As you see in the pictures, the line thickness (exterior contour) is interrupted at some point in this wall end. Im not sure what i am doing wrong.
Thanks,
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
2 Solutions
Lingwisyer
Guru
Unless you are wanting it to use different Pens to the rest of your wall, you should just be checking the toggle "Use Wall's Contour Pen" ("Usar a Caneta de Contorno da Parede" I would assume), then it will just use the Pens matching your Composite.
Ling.
Go to post
Lingwisyer
Guru
Do you have Wall End Lines turned on for the brick layer of your Composite?
Go to post
6 Replies 6
Lingwisyer
Guru
Would it not be better to use the Wrapped End type instead?
Zendrix
Thank you Lingwisyer, that was it. I have another problem now, though, which is that i cant make only the exterior line thicker, when i choose a thickness, it applies it to both the outline cutline and the interior brick line ending.
is there any way to make that happen?
Thank u!
Z
Lingwisyer
Guru
Ling.
Zendrix
I tried that before, but it uses a grey pen on the brick, i dont know why...
Thanks
Z
Lingwisyer
Guru
Zendrix
That was it Lingwisyer, my composite had the brick with a greyish line for the wall end.
Thank you very much!
