‎2025-02-26
09:09 PM
‎2025-02-28
10:46 PM
Hi!
Im having an issue with a wall end in a simple composite wall made of plaster/brick/plaster. As you see in the pictures, the line thickness (exterior contour) is interrupted at some point in this wall end. Im not sure what i am doing wrong.
Thanks,
Z
Solved! Go to Solution.
‎2025-02-28 02:08 AM - edited ‎2025-02-28 02:09 AM
Unless you are wanting it to use different Pens to the rest of your wall, you should just be checking the toggle "Use Wall's Contour Pen" ("Usar a Caneta de Contorno da Parede" I would assume), then it will just use the Pens matching your Composite.
Ling.
‎2025-03-02 10:00 AM
Do you have Wall End Lines turned on for the brick layer of your Composite?
‎2025-02-27 02:27 AM
Would it not be better to use the Wrapped End type instead?
‎2025-02-27
01:10 PM
‎2025-02-28
10:47 PM
Thank you Lingwisyer, that was it. I have another problem now, though, which is that i cant make only the exterior line thicker, when i choose a thickness, it applies it to both the outline cutline and the interior brick line ending.
is there any way to make that happen?
Thank u!
Z
Ling.
‎2025-02-28
01:47 PM
‎2025-02-28
10:47 PM
I tried that before, but it uses a grey pen on the brick, i dont know why...
Thanks
Z
‎2025-03-03 03:54 PM
That was it Lingwisyer, my composite had the brick with a greyish line for the wall end.
Thank you very much!
