yesterday
Hi!
Im having an issue with a wall end in a simple composite wall made of plaster/brick/plaster. As you see in the pictures, the line thickness (exterior contour) is interrupted at some point in this wall end. Im not sure what i am doing wrong.
Thanks,
Z
5 hours ago
Would it not be better to use the Wrapped End type instead?
