Wednesday
- last edited
Friday
Hi!
Im having an issue with a wall end in a simple composite wall made of plaster/brick/plaster. As you see in the pictures, the line thickness (exterior contour) is interrupted at some point in this wall end. Im not sure what i am doing wrong.
Thanks,
Z
Solved! Go to Solution.
Friday - last edited Friday
Unless you are wanting it to use different Pens to the rest of your wall, you should just be checking the toggle "Use Wall's Contour Pen" ("Usar a Caneta de Contorno da Parede" I would assume), then it will just use the Pens matching your Composite.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
Sunday
Do you have Wall End Lines turned on for the brick layer of your Composite?
Thursday
Would it not be better to use the Wrapped End type instead?
Thursday
- last edited
Friday
Thank you Lingwisyer, that was it. I have another problem now, though, which is that i cant make only the exterior line thicker, when i choose a thickness, it applies it to both the outline cutline and the interior brick line ending.
is there any way to make that happen?
Thank u!
Z
Ling.
Friday
- last edited
Friday
I tried that before, but it uses a grey pen on the brick, i dont know why...
Thanks
Z
Sunday
Monday
That was it Lingwisyer, my composite had the brick with a greyish line for the wall end.
Thank you very much!
