JGoode
Nonexistent channel + cannot modify the file error
Hello, I am getting an error with my text file output where it is trying to write to the embedded library but I want it to write to a text file that is already loaded into the library. Fullpath wouldn't work.
chOUT=OPEN ("TEXT", "filelog.TXT", "MODE=WO, LIBRARY")
	OUTPUT chOUT, 1, 1, symb_pos_x
	OUTPUT chOUT, 2, 1, symb_pos_y
	OUTPUT chOUT, 3, 1, symb_pos_z
close chOUT
I was hoping it would seek out the correct file that is loaded into the library (not in LCF format)
Thanks
ArchiCAD 27
Windows 10
Podolsky
Ace
I think the problem here with recordID and fieldID in OUTPUT
This probably will work:
	OUTPUT chOUT, 1, 0, symb_pos_x
	OUTPUT chOUT, 1, 0, symb_pos_y
	OUTPUT chOUT, 1, 0, symb_pos_z
close chOUT
