North Arrow Object with Sunlight gradient
Is there a north arrow that would show the Sun gradient in the summer and winter based on the site coordinates. Like the image posted.
6 REPLIES 6
Aaron Bourgoin
Cadimage have an object that can sit on the outside of your North Compass: Daylight Angle Marker #1544: https://bimcomponents.com/GSM/Details/17712
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
Thank you for the reply. Unfortunately, like the others that have commented on the BIM Components site, I cannot download the file.
Aaron Bourgoin
Can you Download it from the Object Dialog box in AC?
If not PM me and I'll send you a copy.
MacBook M4Pro
Rhino 8.26 Mac
MacOS Tahoe 26.2
This is a curious issue. I experimented a bit:
1. In ARCHICAD 19, if I try to download this object by dragging it onto ARCHICAD 19, it does NOT download.
2. In ARCHICAD 19, if I search for the object in the Object Setting Dialog, find it then click the "Download and Embed" command, it DOES download it and places it in the Embedded Library so I can use it.
3. In ARCHICAD 16, if I try to download this object by dragging it onto ARCHICAD 19, it DOES download it quickly and places it on the Floor Plan right away.
So Method 1 does NOT work, Methods 2 and 3 DO work (for me at least).
I will report this to GRAPHISOFT.
Yes for me, I just downloaded and Embedded object. Then moved it to my Custom Library. Thanks for alerting me of the object, now the "beggar" is wishing it was more interactive with the Project settings. Even if it was date specific and noted the date in the stamp. Either way it may become my new arrow.
Katalin Borszeki
Hi All,
Unfortunately there is a problem which prevents the drag&drop downloading of objects from the BIMcomponents.com which have a “#” in their names.
Until we fix this issue these objects can be downloaded from the Object tool’s search field in ARCHICAD. We plan to fix the issue in a future Update.
Tx, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
