Nader Belal
Mentor
Nurbs -
Hi everyone,
I was trying to take an adventures step to understand nurbs GDL commands, but then I found out that the GDL manual is pretty confusing ... so here goes my questions:
1- Nurbssurface
degree_u: degree of surface in the u parameter direction
degree_v: degree of surface in the v parameter direction
nu, nv: number of control points in u and v directions, greater than degree (not less than order) of then surface in given direction
a- I understand the concept of U,V & W, but how many Knot points in UV must I use to define correctly a nurbs surface ?
b- Suppose that the surface is a rectangular shape with a slight curve, does this mean I have to take 4 points :
(0,0), (0,1), (1,1), (1,0)?
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
11 Replies 11
Nader Belal
Mentor
Thank you, with that I can continue my way
Nader Belal
Mentor
@poco2013
well I started from zero, and I saw another problem, that I although my code was correct using Nurbscurve2D & Nurbscurve3d was correct, it always gave me a error that I have missing parameters.
And now I know why
ArchiCAD uses OpenGL nurbs
Rhino uses openNurbs nurbs
so as long you're aware of the differences, you will get to where you want to go
