‎2018-04-09 10:05 PM
degree_u: degree of surface in the u parameter directiona- I understand the concept of U,V & W, but how many Knot points in UV must I use to define correctly a nurbs surface ?
degree_v: degree of surface in the v parameter direction
nu, nv: number of control points in u and v directions, greater than degree (not less than order) of then surface in given direction
Solved! Go to Solution.
‎2018-04-13 12:36 AM
‎2018-04-10 03:59 PM
‎2018-04-10 05:35 PM
‎2018-04-10 08:26 PM
‎2018-04-11 05:02 PM
Moonlight wrote:Since ver 20 it creates the series of nurbs related comands in 3d script - however the input from Rhino has to be a nurbs object.
Already tried that, the model changes to a mesh object
‎2018-04-12 12:17 AM
by Piotr DobrowolskiNo it doesn't, I have just tried that again after seeing your comment. It changes the body to a mesh using VERT, Edge & Pgon{2}Moonlight wrote:
‎2018-04-13 06:43 AM
‎2018-04-14 02:26 PM
‎2018-04-14 05:31 PM
