‎2018-04-09 10:05 PM
degree_u: degree of surface in the u parameter directiona- I understand the concept of U,V & W, but how many Knot points in UV must I use to define correctly a nurbs surface ?
degree_v: degree of surface in the v parameter direction
nu, nv: number of control points in u and v directions, greater than degree (not less than order) of then surface in given direction
Solved! Go to Solution.
‎2018-04-18 12:17 AM
‎2018-04-18 04:36 PM
