OBJECTS NOT SCHEDULING IN ORDER?
So I have an id_num parameter which can be changed by the user. It is an 'Abc' type parameter. Basically I want it to list in the schedule in order of the id_num but currently it is just listing by element id rather than id_num. Am I going wrong in the code? I need the "Avoid Action" part of the script. It must be reading id_str for each one rather than the actual number and then resorting to using the element id. Any previous experience with this kind of thing? Are there any ways to work around it? Thanks very much.
1 REPLY 1
I am not sure if this is a GDL question or more of a scheduling question.
So you have a parameter in your objects that your users can set and you are happy with that?
If so then it is a scheduling problem (and I will move this post).
You will need to add that parameter as a field in the schedule and then you can sort the order either ascending or descending as you wish.
