OVERRIDE 2D MULLION CURTAIN WALL
Hi!
Is there any way to override the 2D representation of the mullion in the curtain wall tool? It seems that as I try to define the placing of the mullion the 2D representation of the standard mullion is used, even though in the 2D script there is code defined
1 Reply 1
What is your Floor Plan Display setting for your Curtain Wall?
Look in the "Curtain Wall Settings" Dialog, on the "Curtain Wall System" page, in the "Floor Plan and Section" panel, in the "Floor Plan Display" field.
I think it will use the 2D script of the Mullion only if this field is set to "Symbolic" or "Symbolic with Overhead".
