Object Library - Archicad 23
Hi, I have an issue with Archicad 23 (student lisence): the object library has disappeared.
There is only a folder "selected" with a couple of random objects in the object tool. I checked the library manager, and there is Archicad23 library. I've tried to download it from Program files again - nothing has changed. Any recommendation how to fix it?
The issue is not with one file only, it looks the same for all projects.
Thanks!
2 Replies 2
It looks to me like you are searching for 'Favourites' in the object settings.
Just switch to browse the actual library.
Thank you very much!
