Object Library - Archicad 23
Hi, I have an issue with Archicad 23 (student lisence): the object library has disappeared.
There is only a folder "selected" with a couple of random objects in the object tool. I checked the library manager, and there is Archicad23 library. I've tried to download it from Program files again - nothing has changed. Any recommendation how to fix it?
The issue is not with one file only, it looks the same for all projects.
Thanks!
It looks to me like you are searching for 'Favourites' in the object settings.
Just switch to browse the actual library.
Thank you very much!
