โ2023-03-27
03:45 PM
- last edited on
โ2025-02-10
05:21 PM
by
Aruzhan Ilaikova
Hi!
We have a house object (GDL object) we use for sketching early stages. To make sloping roofs we use the ordinary Archicad roof to which we trim the object. However, when the object is trimmed with a roof not going to the edge of the object, the surface material changes to concrete slabs (see attached image). Why does this happen? And how do we avoid it?
Additional info that may or may not be needed:
Thank you!
Kaj
โ2023-03-31 12:48 PM
Hi, I'm not sure if you're the right person to tag, but are you aware if this is a known bug?
Thank you
Kaj
โ2023-04-03 09:45 AM
Hi Kaj,
Sorry for the confusion, but I no longer work for Graphisoft. Please reach out to the local support in your area for further investigation on this matter.
Looking at your problem, I feel like this was a limitation with the way how SEO works. Even if you disable surface override, it's possible that it will still be shown if the object is cut with SEO. If you enable surface override and change it to something else, can it be an acceptable workaround? Or maybe I haven't understood the question fully.
BIM Manager - DKO Architecture - Archicad 28 on Windows 11
โ2023-04-05 10:08 AM
Ah, sorry for the misunderstanding, my bad!
Yes, that is the workaround we use now, but it doesn't always work unfortunately.
โ2023-04-07 07:03 AM
Hmm, that's interesting. If that happens with your own GDL object, I suggest jumping into the Developer forum, as they will be able to help you with such topic
โ2023-04-19 08:08 AM
No, unfortunately not. We have a local reseller looking into it, so hopefully it'll be resolved.
