rhonda gebrael
Object download all same texture as my cupboards
Hi There,
 Im furnishing a bedroom and everything I download from arch cad is all coming in as the same texture as my cubbords, even though im not changing the texture.
 Wether is computer, chair, bed, desk.. They all come in the same texture as the cupboard. How can I modify it to come in as per the original texture it is in the library ?
3 Replies 3
David Maudlin
rhonda:
Look at the Model pane in the Object's Settings to see if the Surface is being overridden. If you cannot se the Model pane, look at Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Object Tool > Model to make it visible.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rhonda gebrael
Do you mean check each single object setting or object setting in general ? and how do I do about that ?
David Maudlin
rhonda:
Select all the objects that are not showing the correct Surface, open the Object Settings, then look at the Model pane and see if it is set to Override Surfaces.
