CAD Teacher Pilla
Object materials visualization problems
I'm having a trouble with a parapet not showing properly on 3D windows and Enscape rendering too.
After some door creations and texture importing in a working file, a parapet I've made stopped showing properly: It was made of steel, but appears semi-transparent now. As you can see on picture (archicad 3D windows and enscape rendering window) it also doesn't properly connect on the edge:
Screenshot 2024-03-27 154007.pngScreenshot 2024-03-27 153943.pngScreenshot 2024-03-27 153909.png
I'm pretty sure is a library problem, because on a brand new file it works, as you can see:
I can't understand how to fix. I tried to refresh libraries...but nothing changed.
Somebody can help?
3 Replies 3
Check your Model View Option settings for railings.
I would say the 3D/elevation settings is not set to "Full".
CAD Teacher Pilla
I've found this option on "Door" settings, but not on "railings" setting
