Object showing hotspots I do not want
A very simple object (a circular fill) with scripted hotspots at the center and centers of top, bottom, and sides (that is: 12, 3, 6, 9 hs) is also showing hotspots at the bounding box corners. This must be some very obvious AC object setting I am missing or some relatively new default hotspots GDL thing I am also missing. Help.
PEN setpen
SET FILL "Solid Fill"
POLY2_B{2} 7, 35, 91, 91,
0, 0, 0,
diam/2, 0, 1,
0, 0, 900,
0, 180, 4001,
-diam/2, 0, 1,
0, 0, 900,
0, 180, 4001,
diam/2, diam/2, -1
HOTSPOT2 0, 0
HOTSPOT2 0, -diam/2
HOTSPOT2 0, diam/2
HOTSPOT2 diam/2, 0
HOTSPOT2 -diam/2,0
Open the object and view the PARAMETERS.
Then press the DETAILS button at the top and turn off the HOTSPOTS ON BOUNDING BOX.
Resave.
That should be it.
Ahahah! Hadn't used it for years. Must be the change to 9 and some lost default or something. Thank you very much.
