ā2004-12-20 11:36 PM
ā2004-12-21 02:19 AM
Ignacio wrote:Open the object and view the PARAMETERS.
A very simple object (a circular fill) with scripted hotspots at the center and centers of top, bottom, and sides (that is: 12, 3, 6, 9 hs) is also showing hotspots at the bounding box corners. This must be some very obvious AC object setting I am missing or some relatively new default hotspots GDL thing I am also missing. Help.
ā2004-12-21 10:05 AM
Barry wrote:Ahahah! Hadn't used it for years. Must be the change to 9 and some lost default or something. Thank you very much.
turn off the HOTSPOTS ON BOUNDING BOX.
