Objects to not rotate in schedules
for a while ago I hade problem that my objects that I've rotated is also rotated in Schedules this I solved with the code
if GLOB_CONTEXT = 2 then
 SYMB_ROTANGLE = 0
 endif
Now I also saw that my angle node is also showing "rotatade" on my schedules.
How do I get my objects to not rotate in schedules
2 Replies 2
Is this version 19 by any chance?
If so then GLOB_CONTEXT can no longer be relied upon.
It should still work with the latest hotfix for 19 with just a warning error message when scripting the object.
But maybe it isn't work properly in 19 now.
It definitely will not work with version 20 next year.
GLOB_CONTEXT has gone and has been replaced with other commands (that aren't as good in my opinion) - which you can get information on here ...
http://gdl.graphisoft.com/gdl-docs/changes-in-ac19/
NOTE these new commands can not be used in the parameter or master scripts.
They will only work in the 2D and 3D scripts as far as I know.
I have yet to sit down and try to work this out myself yet.
here is what i used, has worked so far. for v19
if GLOB_VIEW_TYPE = 9 then
script for schedule
else
script for 2d view
endif
