Old Libraries
I have a collection of 'old libraries' such as Hoshino, Transport and People collection which still have some useful items - these don't seem to work in 8.1. Is there a fix or am I stuck with the limited standard libraries.
Thanks
Harry
5 Replies 5
Djordje
1. Try the Update library technique from the Special menu
2. See the People&More update tip on ArchiGuide
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Ben Odonnell
Thanks
Harry
Harry.
Unfortunately your people and more library will not work in ArchiCAD 8.1 R1.
It is a know problem. It should have been fix for R2 but I haven't had time to test it, so I’m not sure if Graphisoft had time to fix the problem.
But if you follow Djordje's tips the rest should work fine.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Djordje
Ben wrote:
Unfortunately your people and more library will not work in ArchiCAD 8.1 R1. It is a know problem. It should have been fix for R2 but I haven't had time to test it, so I’m not sure if Graphisoft had time to fix the problem.
Hm?
http://www.graphisoft.com/support/archicad/archiguide/PeopleandMoreLibrary.html
Djordje
HP Omen
Thanks Djordje and Ben
..but you're right Ben the tips don't work with people or more in 8.1 - always an error at line 4 or whatever - BINARY 1. Shame as I need lots of work vehicles and boats for a project. I will search the GDL object sites
Thanks
Harry
Djordje
Find the 7.0 Anniversary CDs; also, there is bound to be an unsold Transportation library CD lying somewhere at your dealer's office ...
Djordje
HP Omen
