One pane window object - Is it possible?
How does one create a one-pane window as an object? For example, I would like to make a 10' x 5' (outside dimensions) single pane window; the window tool does not work, as I want to place the pane where there a wall doesn't exist. The closest thing to what I want is the glass curtain wall object. I can set the object dimensions, but I cannot specify less than 2 panels both vertically and horizontally. Sorry if there are obvious solutions to my problem, I couldn't find any. Any help would be appreciated!
Nandor
1 REPLY 1
(if I understand correctly) make a wall the same size (height, width, elevation) as the window. Insert window.
