Rachel137
Only used doors and windows Missing from AC 26 library.
Just updated to Sonoma (Mac) not sure if this is related.
Any doors and windows that were placed in my project are missing from the library.  Library Manager shows them as "missing objects" but the rest of the AC26 library has loaded correctly.  For example all furniture is still present.  All doors and windows that were not placed in my model are showing up correctly in the library.
I have uninstalled and reloaded AC26 and downloaded the latest updates.
I have unloaded and reloaded the AC26 library.
I have re-opened the file, running "open and repair".
Any advice appreciated.
Lingwisyer
Guru
It is not a Migrated project?
The project was started with the library you are loading? Not some other regions one?
You should probably share an image of your Library Manager and other relevant things rather than just typing emphasis.
Yes, it sounds like a library language version problem to me.
The original done with something like the USA library and then after re-install you are using the INT version.
Doors and windows in different language versions are not the same - most other library objects are.
