JGoode
Opening Lines
I have an object that I need to put opening lines on...however I have no idea what the best way to do this is. (The height and width changes) What is the best way of doing this?
ArchiCAD 27
Windows 10
2 Replies 2
David Maudlin
JGoode:
Use the LIN_ x1, y1, z1, x2, y2, z2 command, which draws a line in 3D. If the opening line needs to be dashed, then you will need to code a loop that draws a series of LIN_s with intervening gaps.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erwin Edel
If you dig around in one of the door / window objects, you may be able to find the CALL macro for the opening lines.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
