agroni
Opening line in doors
Hello to you all,
While working on a double leaf door I have stumbled upon an interesting discrepancy concerning the door leaf and opening line.
In the attached image I have presented two situations of the same door type. The left one has the Floor Plan display set to projected view and the right one to symbolic. As you can see, the opening lines on the floor plan don’t match at all!
In this case it is crucial since on the floor plan I need the door in an open state in 102cm also on the Elevation/Section the correct length of the leaf.
Anyone has an idea how can this be repaired?
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
agroni
Update:
I just got information from Graphisoft Support, that this is a bug in Archicad 21. I did not check it in other versions.
Sadly it concerns most of the doors that I have tested.
For all of you that this might impact your project
