jakubc7
Over 50 objects & tools for free - JC Library
Hi everyone. I have a spend quite some time creating my own ArchiCAD objects and tools. It seems a waste to not share them with the rest of the users.
My library contains over 50 objects. My most used ones would include:
- Elevation height marker (perfect for elevation height annotations, links with all the ArchiCAD reference heights)
- column and beam labels (automatically label your beams and column based on complex profile name or A and B size)
- roof slope label (automatically show your roof slope)
- linear grates and floor wastes (I know some users including myself have been looking for this sort of object a while back. This one is fully parametric and with a smart 2d view).
- Brick RL maker (calculates your FFL based on number of bricks, perfect for floor plans, no manual calculations required, no errors - AUS users only)
- Brick coursing elevation maker (I dare say I prefer this over the "other" brick course marker. It stays the same paper size no matter which scale you choose, fully parametric - AUS users only)
- R-Codes calculator for open space and overshadowing (select your zoning, input the numbers and this will give you the results - WA users only)
- Brick section 2d object
- Timber section 2d object
- Typical AL8 and AL12 meter box with custom size option
- Fielders, Rondo 2d tools plus many others
See this video for a showcase of the library:
https://www.youtube.com/watch?v=6oz4Zr7JcFY
I do not charge or plan on charging for any of my objects.
Hope some of you find it useful.
Full library download available here:
http://www.jcdrafting.com.au/
Note: Some objects' user interfaces on v17 library may not work 100& correctly on PC (MAC is fine). I have fixed that issue on v18.
I would appreciate it if a MOD can have my website posted on Graphisoft's GLD links page. I think there are enough object to warrant a post:
http://graphisoft.com.au/downloads/parametric-objects/
Thanks,
Jakub Chruscinski
ArchiCAD 10 - 29 | Windows 11
Lucid Design Studio | Perth, Western Australia
1 Reply 1
I have sent you request to Graphisoft for their consideration.
