Paragraph and Parameters
I created a custom tag in AC14 and save the selection as an object (.gsm)
It has 3 different text elements.
What I want to do now is edit the tag in gdl so that I can establish what the text says via parameters.
The gdl script shows the text as paragraph and when I change the text string in "" and replace it with the parameter i want instead , it gives me an error.
How should I go about it?
Any help is greatly appreciated
EDIT: I figured out how to do this now another question comes to mind. how do I make all this scale independent?
1 Reply 1
could you attached the object rather than the image? It would be easiest way to help you.
There's a global parameter ( A_ ) what returns the scale of plan.
