Parameter Buffer manipulations for text
Nader Belal
Mentor
Hi there,
Is there a way where I can save text strings separated by commas using the PUT, GET() method?
I´m aware the PUT is only for saving numeric values, I need a way that do the same or mimics its behaviour, thank you
Text file?
Text Array parameters? (can be inline defined)
little harder than put/get...
Piotr
4 REPLIES 4
Text file?
Piotr
Nader Belal
Mentor
Ok, so if I wanted to use it with values{2}, how can I adchieve this ?
Nader Belal
Mentor
Thanks Piotr, I have just figured it out
There are a lot of objects in the current standard libs, build the way that there are array/matrix parameters for values/values{2}...and such perps can be made for ui_infield* commands as since AC 19 they can also take the arrays.
Piotr
