vfrontiers
Parameter Display in Object Settings Box
Any chance we will be able to adjust the display widths of the PARAMETERS in an object's SETTING dialog?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
4 Replies 4
David Maudlin
Unless the Parameter Name (description on the left) is longer than 36 characters, I don't see why this section of the dialog box would be stretched at all horizontally, it can be kept to its minimum width.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
vfrontiers
Just to be clear... I am wanting the FILL IN side to be larger... Thus having the stretch would allow me to set the ratio of left to right (which I am assuming is your take too, David?)
Anyway... currently seems disproportional at best.... and really just silly...
Duane
Visual Frontiers
AC3.14 - AC29
Hello,
I think opening the left side, stretching the whole window
and then adjusting the right side wider works.
Regards, Juha
David Maudlin
This is what I thought, but your image does not make the point, it just has a lot of white space. The most common pop up parameter that gets cut off for me is materials, so posting an image that shows the problem would help make your point.
David
