Llian
Storefront Window settings
The wall thickness is 10" and the window frame is 4" thick....where do I find the setting to that? It seems to default to wall thickness...I'm sure there's a way to adjust the frame thickness. Please help. Thanks.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Is this what you are looking for?
If so, check the Frame Depth = Wall Thickness button.
In other types of windows, you will see Frame Thickness = Wall Thickness.
Same thing on Doors.
HTH
Llian
Yes....it works! Thanks.
