ā2011-02-14
10:58 PM
ā2023-05-24
11:52 AM
Rubia Torres
ā2011-02-15 02:23 PM
ā2011-02-15 07:18 PM
David wrote:Maybe I missed them but I had long since finished hiding all the default parameters when these seemed to suddenly appear. The parts were pretty much finished and I was doing the final tweaks. It may be that I started them before some recent changes to the subtype and ArchiCAD decided to update them to the latest settings.
Matthew:
When I select the GS Curtain Wall Door Panel Subtype, these parameters appear in the Main Window, and are part of the ArchiCAD Curtain Wall Door objects, so I think they should have been there from the beginning. When selecting Subtypes, I always end up hiding a bunch of these built in parameters.
ā2011-02-25 10:15 PM
ā2011-02-26 09:56 AM
didrik wrote:I followed my standard rule of just of fixing the problem and leaving the whys and wherefores for later (or never). I made a new blank part of the generic curtain wall panel subtype (not the GS door version) which stripped down the default parameters nicely. I then rebuilt my parameter list and copy/pasted the scripts.
Hmmm. I believe I have experienced a similar phenomenon in an object I created from scratch as a General GDL Object (Model Element "subtype"). Beginner that I am, I took this as "imagination overdrive."
Key thing is, have you arrived at an explanation for it, or has it been solved?
