Parameters Template for Block Conversion?
I'm sure someone out there knows how to do this:
I am importing a bunch of Autocad blocks and converting them to Archicad lib parts for scheduling purposes. I want to set up a number(5-10) of parameters in each imported library part has the same parameter list.
Is there a way to make a library part template to create the desired list of parameters for my DWG Translator?
Alternatively(although I think this is not possible), how can I insert a group of parameters into an existing bunch of library parts without going through the library part interface?
Thanks.
-Nathan Brauer
1 Reply 1
What you want is accomplished via subtype templates. AFAIK, there is no way to specify a default subtype in the DWG translator. [I think this would be an excellent wishlist item.]
You can insert the group of common parameters by defining a subtype and assigning that subtype to each of your new parts. See this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=26630&highlight=create+subtype#26630
However, the 'easy' method does require you to open each part and change the subtype in the library part interface.
If you have a huge number of parts, then it is worth looking into the XML tools under the Support/Developer links on the GS web site and converting all of your 'new' parts to XML and scripting the change of subtype there, then converting all back to library parts.
HTH,
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
