Hi all,
We are thrilled to share the story behind Lorenzo Ferla's LEGO object, highlight of our Parametric Object Factory challenge.
If you are curious to learn how Lorenzo creatively approached this task and learning GDL, or would like to download this and many other objects from the challenge, check our Insights post.
You are invited to try out and experiment with those parametric objects yourself. There are a few that are sure to be handy for your projects!
Thank you to all participants for sharing their great works. See you in the next challenge! 😉
Rubia TorresCommunity Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
