Part Section Marker Background Fill - GDL
Hello all and Happy New year,
We use a section marker with different ends to reference section details etc, a circle plus text and arrow at one end and a rectangle tail at the other as in the attached.
We couldn't find a marker in the version of Archicad we use that could accomplish this so after a lot of searching I found the 'Section Park Marker' which is exactly what we need, however the circle with text in doesn't have a background fill, as shown by the blue line in the attached.
I've been trying to edit the script to give the circle a fill with no luck, would anyone be able to help please, or can anyone point me to a better marker?!! I tried replacing circle2 with Poly2 as a stab in the dark with no luck...!
The script I believe is for the 2D representation of the marker is below. Thanks in advance!
!!!************************************ Section Part Marker_NCS ************************
IF elev_sect_mark_US_type = 2 THEN
	pen gs_cont_pen
	! centered, always horizontal marker text
	style centerstyle
	dist=AC_MarkerSize/sqr(2)
	mark_rad=AC_MarkerSize/2		!!!*sqr(2)
	If not(SYMB_MIRRORED) Then
		If gs_flipp Then
			flipp=1
		Else
			flipp=0
		EndIf
	Else
		If gs_flipp Then
			flipp=0
		Else
			flipp=1
		EndIf
	EndIf
	If not(flipp) Then
		unID=1
		hotspot2 0,0,unID : unID=unID+1
		hotspot2 -dist,0,unID : unID=unID+1
		hotspot2 -dist,dist,unID : unID=unID+1
		hotspot2 -2*dist,0,unID : unID=unID+1
		add2 -dist,0
		for i=1 to 2
			poly2_b	5, 7, gs_backfill_pen_fg, gs_backfill_pen_bg,
					-dist, 0, 1,
					-mark_rad, 0, 1,
					0, 0, 901,
					mark_rad, -45, 4001,
					-dist, 0, -1
			mul2 -1,1
		next i
		del 2
				0, dist, 1,
				mark_rad*sqr(2)/2, mark_rad*sqr(2)/2, 1,
				0, 0, 901,
				mark_rad, 90, 4001,
				0, dist, -1
		circle2 0,0,mark_rad
		!!! Text division line !!!!!!!!!!!!!!!
		if gs_marker_text_rotation_int = 1 or gs_marker_text_rotation_int = 2 then	! Horizontal, Vertical
			mrr = SYMB_MIRRORED - not(SYMB_MIRRORED)	! 1 / -1
			rot2 SYMB_ROTANGLE * mrr					! reset x to horizontal
			if gs_marker_text_rotation_int = 2 then
				rot2 90
			endif
		endif
		line2 -mark_rad,0,mark_rad,0
			if gs_marker_text_rotation_int = 2 then del 1
			del 1
		endif
	Else
		thk=0.0015*1000
		len=0.0030*1000
		gs_fill_pen=1 : gs_back_pen=91
				0, 0, 1,
				0, len, 1,
				-thk, len, 1,
				-thk, 0, 1,
				0, 0, -1
	endif
ENDIF
4 REPLIES 4
David Maudlin
PrendosJoe:
This is a guess as I just scanned the code, but I am thinking that the line:
is the circle. So just after this line your would add a line of code for the fill using the POLY2_ command (or other versions of it if you want more control) after setting the fill you want to use. Since the Poly2_ command has Status values, you can use the Additional Status Codes (see the GDL Reference Guide) to draw the circle.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
This one makes a poly circle with contour line
poly2_B 6, 1+2+4, gs_fill_pen,gs_back_pen,
	mark_rad,	0,	1,
	0,			0,	901,
	0,			180,	4001,
	0,			0,	901,
	0,			180,	4001,
	mark_rad,	        0,	-1
Fantastic, thank you very much both!
The only issue with this is that the background pen of the circle and the arrow are now the same, whereas we would prefer the arrow part to be black and the circle white. Is this relatively straight forward or would it require a new parameter adding etc?
Many thanks
You could use the screen pen (usually white) for the background, it
has the index number -1.
fill "Empty"
poly2_B 6, 1+2+4, gs_cont_pen, -1,
   mark_rad,   0,   1,
   0,         0,   901,
   0,         180,   4001,
   0,         0,   901,
   0,         180,   4001,
   mark_rad,           0,   -1
