amtroy
Rotating Objects on Z plane
Hi, I'm trying to rotate this shower wall object I downloaded from the Kohler website as an RFA file, (Archicad 28)
How do I rotate on it's Z axis so I can place this shower component on the wall? I'm always locked into the x,y, axis.
I've tried changing the editing plane, going to a section and trying to rotate, I come from a revit, sketchup background and this is a very simple task so I'm at a bit of a loss!
Thanks,
Operating system used: Mac Intel-based
1 Solution
vlahtinen
Try to convert the object first to a morph and then rotate. You might need to change the editing plane to vertical. After the rotation you can save the morph again as an object, if you wish.
Go to post
vlahtinen
amtroy
thanks!
