People and Trees for AC 10
There are people and trees as bitmap-pictures for 3D renderings.
Is there any possibility to put some more pictures in these people bitmap from myself?
13 Replies 13
Hi Archi User 77,
Do you mean change the picture in the object to another one?
Could you be more specific?
Braza
In AC10 you can use own pictures from outside.
But how can I put this picture?
What I have shown are the existing original bitmap picture.
Dwight
The Object "People Bitmap 10" found in the USA version has a provision for CUSTOM images.
You'll need something like Photoshop to mask your image - study the other images to see how the alpha channel masks around the figure.
Once the image is prepared, it must be saved in a folder within the library AND loaded into the library.
Dwight Atkinson
Hello Dwight,
I'll try it.
I can not load... How can I load?
Dwight
Any file in a folder can be loaded into the library - Check your Library Manager dialog box.
Dwight Atkinson
To load is no problem.
But how can I pick the loaded picture into People Bitmap 10 as Custm images?
Dwight
write the file name in the space that appears when you pick CUSTOM
Dwight Atkinson
Thanks Dwight
It works.....Why it works I dont know, but it works...
tif files are also ok.
