GDL Editor Fonts
TomWaltz
Does anyone know if there is a way to control the fonts in the GDL editor windows?
For some reason, on two different machines running OS 10.4.6, my fonts are different. One is a nice, normal font. The other is this annoying light gray thin font that I can barely read.
Anyone else seen this? Or fixed it?
Tom Waltz
9 REPLIES 9
Thomas Holm
Screen dump, please?
Frank Beister
Go to the editor window into a script. Menu "Edit>Text style". Was this you are looking for?
TomWaltz
That's exactly it. Thanks!!
Tom Waltz
Frank Beister
Looks like someone on "the other" machine has gambled a bit.
TomWaltz
How do you mean?
Tom Waltz
Frank Beister
Normally the font does not change by itself, isn't it? I guess there's no hotkey for accidentally changes too. 😉
TomWaltz
That's the weird part.... one machine is OK in AC9 but flaky in AC10, the other is flaky in AC9 and OK in AC10.... makes me believe in Gremlins!
Tom Waltz
I have the same problem with fonts. I work in AC7. The problem has arisen after I have made updating up to R3. When I open window GDL of the editor, the good font " Courier New " which is established in the menu " Edit> Text style " is seen. But during a writing of a script, it varies on narrow font.
Likely it is edited in a file of the register, but I do not know where. Can experts from Graphisoft will help?
WinXP SP1, AthlonXP 2600+, 512Mb RAM, NVIDIA GeForce FX 5200 128Mb.
undefined
I have always had a problem with GDL environment settings reverting to default fonts and window sizes. It seems to happen when editing parts on different machines. I gave up trying to make changes stick. These settings should be in the Work Environment.
Other than that, the GDL environment is a perfect, modern IDE.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
