Place all objects of loaded libraries on floor plan
I used to have an interesting trick in ArchiCAD 6.5 (WINDOWS platform) to place all library objects on the floor plan by once, while holding the SHIFT button starting the program. Recently I discovered having problems to do so in ArchiCAD 9. Who can help to find the way to return to this easy tool in version 9? WIN XP or MAC OSX ? It would be of great help while re-assembling my personalized libraries. Thanks
10 Replies 10
David Wrote
Open a new file, go to the Library Manager, and load only the library you want in the archive. Now go to File>Save As... and under Format select ArchiCAD Archive Project, click on the Options button and check Include All Parts of Loaded Libraries. Now save the archive. This should create an archive with only the loaded library, even if no parts have been placed in the plan.
Hi David
This works & is so simple
Thanks
Hi Djordje
The Special Menu seems to have had its Functions Removed in Aust Mac version
