Placing multiple skylight windows
Hello, im quite new to archicad, and i need some help placing multiple skylight windows. Im not that good in explaining these kind of things in english, but i'll give it a go. Hope you understand what i mean.
I've placed 5 skylight windows next to eachother, and the problem accures under the roof (inside the room). In between every skylight window, the roof seem to make a "wall" between the windows. Its actually the roof that is making these "walls". What i want is that the skylight windows wont make a little glipse of wall between every window. I want them to be like when i place regular windows next to eachother. No wall between them.
Did anyone understand?
I have a picture..
undefined
4 REPLIES 4
Erika Epstein
Yamsan,
Please add your archicad version and OS to your profile.
The skylights may not be cutting holes in the roofs Perpendicular or vertical to your roof. Seehere
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I would cut the roof hole manually and then I would add the skylights manually as well, but by using the object tool, not the skylight tool.
Best Regards,
Piotr
I also use Piotr's method. Skylight tool is buggy.
Thanks Piotr, that worked perfectly
Erika, i will
