Pop-up menu not working- Not recognizing .txt file?
Trying to get a library called BruciCad(Aussies will know which one) working. It references to a text file for some of the library parts. Problem is that the pop up menus dont appear in, lets say, the tap object which should let me choose from a number of proprietory taps.
The .txt file is in the root Archicad folder, but the objects dont seem to find it.
I have got it working on some computers at work but not others, including mine.
I am running the latest Archicad and XP. Any advise would be much appreciated
__archiben
put the text file in the archiBrucie library rather than the archicad directory . . . and don't forget to reload your libraries cobber.
~/archiben
b e n _ f r o s t
Still no go. Have tried putting the txt file lotsa different places.
Here is part of the master script if that helps
INCVALUE=1
CH1=OPEN("DATA","B70GlobSet.txt","SEPARATOR='~',MODE=RO")
FOR COUNT1=7110.41 TO 7110.61 STEP 0.01
Also a screenshot of the object popup not working
