Powerful gdL string [CALCULATOR] Beta version
I have finished my gdl Calculator,
so it can be helpful for a various
calculations in the plans, working sheets etc.
- There are two different ways of data entering:
1 - ID field in InfoBox for short expressions, or
2 - Dialogue window for fullsize expressions and settings.
- Calculator works with Parentheses
- It is now realised thrigonometric and other functions,
- Also Calculator knows some of Math constants.
All Remarks are accepted.
Thnks for betatesting the subj
6 Replies 6
Wokka
Nice little object.
Should be able to find a use for it.
I couldn't get the colours to work??
Cheers and thanks!
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
what you do mean about colors?
This is brilliant.
You know what I'm seeing when I look at this? I'm seeing a small spreadsheet object that calls these objects as macros to create spreadsheet cells. These calculator-cells could return their results, which could be used in other 'cells' as part of calculations.
I tried it briefly with three cells, and it seems that it's technically possible. The real challenge would be a GUI that works. Anyone up for the challenge?
Another ability is a
Function grafix, like Moments epures, curves of falling water, spirograf, any other geometric functions.
PS i've done a spirograf and waterstream falling curve.
Make sure to upload it into the Object Depository when the final version is completed.
