Problem rotating an object
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-09-09
12:27 AM
‎2023-05-24
12:07 PM
Rubia Torres
I thought I remember in the introduction to AC10 class that this was a new feature, however I can only seam to rotate around a single plane, same as the 2D window, or drawing window.
I have saved a loudspeaker as a library part, now I need to be able to hang it from the ceiling and rotate it down to point at the floor at about a 40 degree angle, or any angle for that matter.
Am I stuck? I thought this was a new feature of 10??
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-10 03:09 AM
Dwight, I have already inquired about ArchiForma, looks like such a nice add-on to build objects, which I desperately need. Thank you for the info!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-10 03:14 AM
I have been tempted to get ArchiForma.
Could you answer a few questions about it please.
Are the scripts hidden or locked ?
Do the scripts use primitives ?
Are the objects created hollow or surface only ?
Thanks,
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-10 03:20 AM
You can give xrot any value plus of minus.
You can create a yrot parameter as well.
No need for a zrot because you can do this in the plan
or in the lib part settings.
Good luck,
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-10 03:59 AM
Peter wrote:1: ArchiForma is a parametric object with its own rules. You don't make them into other things by editing the script.
Hello Dwight,
1: Are the scripts hidden or locked ?
2: Do the scripts use primitives?
3: Do squirrels eat cheese?
4: Are the objects created hollow or surface only ?
Thanks,
Peter Devlin
2: They use sophisticates, not primitives. Those are the kinds of scripts that speak Italian and smoke with long cigarette holders instead of English-speaking Bull Durham rollyerowns. Call them perimetrosexuals. You are assessing the potential to create GDL parametric elements using ARCHIFORMA. FUGGEDABOUDIT.
3: Yes, but they prefer nuts.
4: Yes. Is there a difference? Archicad is a surface modeler, not a solid modeler.
If you dare, make sense of the script from that red twisted object saved as a Library Element:
! Name : ARCHIFORMA TWISTER.gsm
! Date : Saturday, September 09, 2006
! Version : 10.00
! Written by ArchiCAD
mulx A/6'-5.3253"
muly B/3'-6.7594"
mulz ZZYZX/5'-11.5327"
addx 185'-6.7498"
addy 69'-11.3697"
addz -14'-11.8959"
rotz 270
body -1
model solid
resol 36
GLOB_SCRIPT_TYPE = 3
GLOB_CONTEXT = 3
GLOB_SCALE = 1
GLOB_NORTH_DIR = 90
GLOB_DRAWING_BGD_PEN = 241
GLOB_FRAME_NR = -1
GLOB_EYEPOS_X = 65'-11.7353"
GLOB_EYEPOS_Y = -174'-0.9329"
GLOB_EYEPOS_Z = 23'-7.1038"
GLOB_TARGPOS_X = 67'-6.7635"
GLOB_TARGPOS_Y = -176'-2.9987"
GLOB_TARGPOS_Z = 22'-3.1386"
GLOB_SUN_AZIMUTH = 45
GLOB_SUN_ALTITUDE = 70
body -1
body -1
body -1
body -1
GLOB_HSTORY_HEIGHT = 0'-8.2536"
!!ArchiForma 2.0
WALL_ID = "WL83"
WALL_RESOL = 36
WALL_THICKNESS = 0'-8.0000"
WALL_START_THICKNESS = 0'-8.0000"
WALL_END_THICKNESS = 0'-8.0000"
WALL_HEIGHT = 8'-10.5658"
WALL_LINETYPE = 1
WALL_FILL = 16
WALL_FILL_PEN = 250
WALL_SECT_PEN = 255
WALL_VIEW_PEN = 255
WALL_FBGD_PEN = 8
WALL_POSITION[1] = 0'-0.0000"
WALL_POSITION[2] = 0'-0.0000"
WALL_POSITION[3] = 0'-0.0000"
WALL_MAT_A = 45
WALL_MAT_B = 45
WALL_MAT_EDGE = 45
GLOB_ELEVATION = 15'-10.7365"
SYMB_LINETYPE = 1
SYMB_FILL = 243
SYMB_FILL_PEN = 1
SYMB_FBGD_PEN = 1
SYMB_SECT_PEN = 1
SYMB_VIEW_PEN = 1
SYMB_MAT = 151
SYMB_POS_X = 68'-1.9900"
SYMB_POS_Y = -179'-10.6743"
SYMB_POS_Z = 15'-10.7365"
SYMB_A_SIZE = 3'-3.3701"
SYMB_B_SIZE = 3'-3.3701"
GLOB_CUTPLANES_INFO[1] = 0'-8.2536"
GLOB_CUTPLANES_INFO[2] = 0'-8.2536"
GLOB_CUTPLANES_INFO[3] = 0'-0.0000"
GLOB_CUTPLANES_INFO[4] = 0'-0.0000"
WALL_THICKNESS = 0'-0.0000"
pen 1
set material "Rietveld Red"
GLOB_LAYER = " steel pieces"
GLOB_ID = "ArchiForma 2.0"
GLOB_INTID = 17345
GLOB_ELEM_TYPE = 1
body -1
add 68'-1.9900", -179'-10.6743", 15'-10.7365"
DIM tmp_hole_type[20]
tmp_hole_type[1] = -1
tmp_hole_type[2] = -1
tmp_hole_type[3] = -1
tmp_hole_type[4] = -1
tmp_hole_type[5] = -1
tmp_hole_type[6] = -1
tmp_hole_type[7] = -1
tmp_hole_type[8] = -1
tmp_hole_type[9] = -1
tmp_hole_type[10] = -1
tmp_hole_type[11] = -1
tmp_hole_type[12] = -1
tmp_hole_type[13] = -1
tmp_hole_type[14] = -1
tmp_hole_type[15] = -1
tmp_hole_type[16] = -1
tmp_hole_type[17] = -1
tmp_hole_type[18] = -1
tmp_hole_type[19] = -1
tmp_hole_type[20] = -1
DIM tmp_hole_XYZ[20][3]
tmp_hole_XYZ[1][1] = 0'-0.0000"
tmp_hole_XYZ[1][2] = 0'-0.0000"
tmp_hole_XYZ[1][3] = 0'-0.0000"
tmp_hole_XYZ[2][1] = 0'-0.0000"
tmp_hole_XYZ[2][2] = 0'-0.0000"
tmp_hole_XYZ[2][3] = 0'-0.0000"
tmp_hole_XYZ[3][1] = 0'-0.0000"
tmp_hole_XYZ[3][2] = 0'-0.0000"
tmp_hole_XYZ[3][3] = 0'-0.0000"
tmp_hole_XYZ[4][1] = 0'-0.0000"
tmp_hole_XYZ[4][2] = 0'-0.0000"
tmp_hole_XYZ[4][3] = 0'-0.0000"
tmp_hole_XYZ[5][1] = 0'-0.0000"
tmp_hole_XYZ[5][2] = 0'-0.0000"
tmp_hole_XYZ[5][3] = 0'-0.0000"
tmp_hole_XYZ[6][1] = 0'-0.0000"
tmp_hole_XYZ[6][2] = 0'-0.0000"
tmp_hole_XYZ[6][3] = 0'-0.0000"
tmp_hole_XYZ[7][1] = 0'-0.0000"
tmp_hole_XYZ[7][2] = 0'-0.0000"
tmp_hole_XYZ[7][3] = 0'-0.0000"
tmp_hole_XYZ[8][1] = 0'-0.0000"
tmp_hole_XYZ[8][2] = 0'-0.0000"
tmp_hole_XYZ[8][3] = 0'-0.0000"
tmp_hole_XYZ[9][1] = 0'-0.0000"
tmp_hole_XYZ[9][2] = 0'-0.0000"
tmp_hole_XYZ[9][3] = 0'-0.0000"
tmp_hole_XYZ[10][1] = 0'-0.0000"
tmp_hole_XYZ[10][2] = 0'-0.0000"
tmp_hole_XYZ[10][3] = 0'-0.0000"
tmp_hole_XYZ[11][1] = 0'-0.0000"
tmp_hole_XYZ[11][2] = 0'-0.0000"
tmp_hole_XYZ[11][3] = 0'-0.0000"
tmp_hole_XYZ[12][1] = 0'-0.0000"
tmp_hole_XYZ[12][2] = 0'-0.0000"
tmp_hole_XYZ[12][3] = 0'-0.0000"
tmp_hole_XYZ[13][1] = 0'-0.0000"
tmp_hole_XYZ[13][2] = 0'-0.0000"
tmp_hole_XYZ[13][3] = 0'-0.0000"
tmp_hole_XYZ[14][1] = 0'-0.0000"
tmp_hole_XYZ[14][2] = 0'-0.0000"
tmp_hole_XYZ[14][3] = 0'-0.0000"
tmp_hole_XYZ[15][1] = 0'-0.0000"
tmp_hole_XYZ[15][2] = 0'-0.0000"
tmp_hole_XYZ[15][3] = 0'-0.0000"
tmp_hole_XYZ[16][1] = 0'-0.0000"
tmp_hole_XYZ[16][2] = 0'-0.0000"
tmp_hole_XYZ[16][3] = 0'-0.0000"
tmp_hole_XYZ[17][1] = 0'-0.0000"
tmp_hole_XYZ[17][2] = 0'-0.0000"
tmp_hole_XYZ[17][3] = 0'-0.0000"
tmp_hole_XYZ[18][1] = 0'-0.0000"
tmp_hole_XYZ[18][2] = 0'-0.0000"
tmp_hole_XYZ[18][3] = 0'-0.0000"
tmp_hole_XYZ[19][1] = 0'-0.0000"
tmp_hole_XYZ[19][2] = 0'-0.0000"
tmp_hole_XYZ[19][3] = 0'-0.0000"
tmp_hole_XYZ[20][1] = 0'-0.0000"
tmp_hole_XYZ[20][2] = 0'-0.0000"
tmp_hole_XYZ[20][3] = 0'-0.0000"
DIM tmp_hole_angle[20]
tmp_hole_angle[1] = 0
tmp_hole_angle[2] = 0
tmp_hole_angle[3] = 0
tmp_hole_angle[4] = 0
tmp_hole_angle[5] = 0
tmp_hole_angle[6] = 0
tmp_hole_angle[7] = 0
tmp_hole_angle[8] = 0
tmp_hole_angle[9] = 0
tmp_hole_angle[10] = 0
tmp_hole_angle[11] = 0
tmp_hole_angle[12] = 0
tmp_hole_angle[13] = 0
tmp_hole_angle[14] = 0
tmp_hole_angle[15] = 0
tmp_hole_angle[16] = 0
tmp_hole_angle[17] = 0
tmp_hole_angle[18] = 0
tmp_hole_angle[19] = 0
tmp_hole_angle[20] = 0
DIM tmp_hole_angle2[20][3]
tmp_hole_angle2[1][1] = 0
tmp_hole_angle2[1][2] = 0
tmp_hole_angle2[1][3] = 0
tmp_hole_angle2[2][1] = 0
tmp_hole_angle2[2][2] = 0
tmp_hole_angle2[2][3] = 0
tmp_hole_angle2[3][1] = 0
tmp_hole_angle2[3][2] = 0
tmp_hole_angle2[3][3] = 0
tmp_hole_angle2[4][1] = 0
tmp_hole_angle2[4][2] = 0
tmp_hole_angle2[4][3] = 0
tmp_hole_angle2[5][1] = 0
tmp_hole_angle2[5][2] = 0
tmp_hole_angle2[5][3] = 0
tmp_hole_angle2[6][1] = 0
tmp_hole_angle2[6][2] = 0
tmp_hole_angle2[6][3] = 0
tmp_hole_angle2[7][1] = 0
tmp_hole_angle2[7][2] = 0
tmp_hole_angle2[7][3] = 0
tmp_hole_angle2[8][1] = 0
tmp_hole_angle2[8][2] = 0
tmp_hole_angle2[8][3] = 0
tmp_hole_angle2[9][1] = 0
tmp_hole_angle2[9][2] = 0
tmp_hole_angle2[9][3] = 0
tmp_hole_angle2[10][1] = 0
tmp_hole_angle2[10][2] = 0
tmp_hole_angle2[10][3] = 0
tmp_hole_angle2[11][1] = 0
tmp_hole_angle2[11][2] = 0
tmp_hole_angle2[11][3] = 0
tmp_hole_angle2[12][1] = 0
tmp_hole_angle2[12][2] = 0
tmp_hole_angle2[12][3] = 0
tmp_hole_angle2[13][1] = 0
tmp_hole_angle2[13][2] = 0
tmp_hole_angle2[13][3] = 0
tmp_hole_angle2[14][1] = 0
tmp_hole_angle2[14][2] = 0
tmp_hole_angle2[14][3] = 0
tmp_hole_angle2[15][1] = 0
tmp_hole_angle2[15][2] = 0
tmp_hole_angle2[15][3] = 0
tmp_hole_angle2[16][1] = 0
tmp_hole_angle2[16][2] = 0
tmp_hole_angle2[16][3] = 0
tmp_hole_angle2[17][1] = 0
tmp_hole_angle2[17][2] = 0
tmp_hole_angle2[17][3] = 0
tmp_hole_angle2[18][1] = 0
tmp_hole_angle2[18][2] = 0
tmp_hole_angle2[18][3] = 0
tmp_hole_angle2[19][1] = 0
tmp_hole_angle2[19][2] = 0
tmp_hole_angle2[19][3] = 0
tmp_hole_angle2[20][1] = 0
tmp_hole_angle2[20][2] = 0
tmp_hole_angle2[20][3] = 0
DIM tmp_hole_angoletto[20]
tmp_hole_angoletto[1] = 0
tmp_hole_angoletto[2] = 0
tmp_hole_angoletto[3] = 0
tmp_hole_angoletto[4] = 0
tmp_hole_angoletto[5] = 0
tmp_hole_angoletto[6] = 0
tmp_hole_angoletto[7] = 0
tmp_hole_angoletto[8] = 0
tmp_hole_angoletto[9] = 0
tmp_hole_angoletto[10] = 0
tmp_hole_angoletto[11] = 0
tmp_hole_angoletto[12] = 0
tmp_hole_angoletto[13] = 0
tmp_hole_angoletto[14] = 0
tmp_hole_angoletto[15] = 0
tmp_hole_angoletto[16] = 0
tmp_hole_angoletto[17] = 0
tmp_hole_angoletto[18] = 0
tmp_hole_angoletto[19] = 0
tmp_hole_angoletto[20] = 0
DIM tmp_hole_rotazione[20]
tmp_hole_rotazione[1] = 0
tmp_hole_rotazione[2] = 0
tmp_hole_rotazione[3] = 0
tmp_hole_rotazione[4] = 0
tmp_hole_rotazione[5] = 0
tmp_hole_rotazione[6] = 0
tmp_hole_rotazione[7] = 0
tmp_hole_rotazione[8] = 0
tmp_hole_rotazione[9] = 0
tmp_hole_rotazione[10] = 0
tmp_hole_rotazione[11] = 0
tmp_hole_rotazione[12] = 0
tmp_hole_rotazione[13] = 0
tmp_hole_rotazione[14] = 0
tmp_hole_rotazione[15] = 0
tmp_hole_rotazione[16] = 0
tmp_hole_rotazione[17] = 0
tmp_hole_rotazione[18] = 0
tmp_hole_rotazione[19] = 0
tmp_hole_rotazione[20] = 0
DIM tmp_hole_zzyzx[20]
tmp_hole_zzyzx[1] = 3'-3.3701"
tmp_hole_zzyzx[2] = 3'-3.3701"
tmp_hole_zzyzx[3] = 3'-3.3701"
tmp_hole_zzyzx[4] = 3'-3.3701"
tmp_hole_zzyzx[5] = 3'-3.3701"
tmp_hole_zzyzx[6] = 3'-3.3701"
tmp_hole_zzyzx[7] = 3'-3.3701"
tmp_hole_zzyzx[8] = 3'-3.3701"
tmp_hole_zzyzx[9] = 3'-3.3701"
tmp_hole_zzyzx[10] = 3'-3.3701"
tmp_hole_zzyzx[11] = 3'-3.3701"
tmp_hole_zzyzx[12] = 3'-3.3701"
tmp_hole_zzyzx[13] = 3'-3.3701"
tmp_hole_zzyzx[14] = 3'-3.3701"
tmp_hole_zzyzx[15] = 3'-3.3701"
tmp_hole_zzyzx[16] = 3'-3.3701"
tmp_hole_zzyzx[17] = 3'-3.3701"
tmp_hole_zzyzx[18] = 3'-3.3701"
tmp_hole_zzyzx[19] = 3'-3.3701"
tmp_hole_zzyzx[20] = 3'-3.3701"
DIM tmp_hole_lati[20]
tmp_hole_lati[1] = 4
tmp_hole_lati[2] = 4
tmp_hole_lati[3] = 4
tmp_hole_lati[4] = 4
tmp_hole_lati[5] = 4
tmp_hole_lati[6] = 4
tmp_hole_lati[7] = 4
tmp_hole_lati[8] = 4
tmp_hole_lati[9] = 4
tmp_hole_lati[10] = 4
tmp_hole_lati[11] = 4
tmp_hole_lati[12] = 4
tmp_hole_lati[13] = 4
tmp_hole_lati[14] = 4
tmp_hole_lati[15] = 4
tmp_hole_lati[16] = 4
tmp_hole_lati[17] = 4
tmp_hole_lati[18] = 4
tmp_hole_lati[19] = 4
tmp_hole_lati[20] = 4
DIM tmp_hole_lung[20]
tmp_hole_lung[1] = 0'-7.8740"
tmp_hole_lung[2] = 0'-7.8740"
tmp_hole_lung[3] = 0'-7.8740"
tmp_hole_lung[4] = 0'-7.8740"
tmp_hole_lung[5] = 0'-7.8740"
tmp_hole_lung[6] = 0'-7.8740"
tmp_hole_lung[7] = 0'-7.8740"
tmp_hole_lung[8] = 0'-7.8740"
tmp_hole_lung[9] = 0'-7.8740"
tmp_hole_lung[10] = 0'-7.8740"
tmp_hole_lung[11] = 0'-7.8740"
tmp_hole_lung[12] = 0'-7.8740"
tmp_hole_lung[13] = 0'-7.8740"
tmp_hole_lung[14] = 0'-7.8740"
tmp_hole_lung[15] = 0'-7.8740"
tmp_hole_lung[16] = 0'-7.8740"
tmp_hole_lung[17] = 0'-7.8740"
tmp_hole_lung[18] = 0'-7.8740"
tmp_hole_lung[19] = 0'-7.8740"
tmp_hole_lung[20] = 0'-7.8740"
DIM tmp_hole_enne[20]
tmp_hole_enne[1] = 0
tmp_hole_enne[2] = 0
tmp_hole_enne[3] = 0
tmp_hole_enne[4] = 0
tmp_hole_enne[5] = 0
tmp_hole_enne[6] = 0
tmp_hole_enne[7] = 0
tmp_hole_enne[8] = 0
tmp_hole_enne[9] = 0
tmp_hole_enne[10] = 0
tmp_hole_enne[11] = 0
tmp_hole_enne[12] = 0
tmp_hole_enne[13] = 0
tmp_hole_enne[14] = 0
tmp_hole_enne[15] = 0
tmp_hole_enne[16] = 0
tmp_hole_enne[17] = 0
tmp_hole_enne[18] = 0
tmp_hole_enne[19] = 0
tmp_hole_enne[20] = 0
DIM tmp_hole_perimetro[50][80]
tmp_hole_perimetro[1][1] = 0'-0.0000"
tmp_hole_perimetro[1][2] = 0'-0.0000"
tmp_hole_perimetro[1][3] = 0'-0.0000"
tmp_hole_perimetro[1][4] = 0'-0.0000"
tmp_hole_perimetro[1][5] = 0'-0.0000"
tmp_hole_perimetro[1][6] = 0'-0.0000"
tmp_hole_perimetro[1][7] = 0'-0.0000"
tmp_hole_perimetro[1][8] = 0'-0.0000"
tmp_hole_perimetro[1][9] = 0'-0.0000"
tmp_hole_perimetro[1][10] = 0'-0.0000"
tmp_hole_perimetro[1][11] = 0'-0.0000"
tmp_hole_perimetro[1][12] = 0'-0.0000"
tmp_hole_perimetro[1][13] = 0'-0.0000"
tmp_hole_perimetro[1][14] = 0'-0.0000"
tmp_hole_perimetro[1][15] = 0'-0.0000"
tmp_hole_perimetro[1][16] = 0'-0.0000"
tmp_hole_perimetro[1][17] = 0'-0.0000"
tmp_hole_perimetro[1][18] = 0'-0.0000"
tmp_hole_perimetro[1][19] = 0'-0.0000"
tmp_hole_perimetro[1][20] = 0'-0.0000"
tmp_hole_perimetro[1][21] = 0'-0.0000"
tmp_hole_perimetro[1][22] = 0'-0.0000"
tmp_hole_perimetro[1][23] = 0'-0.0000"
tmp_hole_perimetro[1][24] = 0'-0.0000"
tmp_hole_perimetro[1][25] = 0'-0.0000"
tmp_hole_perimetro[1][26] = 0'-0.0000"
tmp_hole_perimetro[1][27] = 0'-0.0000"
tmp_hole_perimetro[1][28] = 0'-0.0000"
tmp_hole_perimetro[1][29] = 0'-0.0000"
tmp_hole_perimetro[1][30] = 0'-0.0000"
tmp_hole_perimetro[1][31] = 0'-0.0000"
tmp_hole_perimetro[1][32] = 0'-0.0000"
tmp_hole_perimetro[1][33] = 0'-0.0000"
tmp_hole_perimetro[1][34] = 0'-0.0000"
tmp_hole_perimetro[1][35] = 0'-0.0000"
tmp_hole_perimetro[1][36] = 0'-0.0000"
tmp_hole_perimetro[1][37] = 0'-0.0000"
tmp_hole_perimetro[1][38] = 0'-0.0000"
tmp_hole_perimetro[1][39] = 0'-0.0000"
tmp_hole_perimetro[1][40] = 0'-0.0000"
tmp_hole_perimetro[1][41] = 0'-0.0000"
tmp_hole_perimetro[1][42] = 0'-0.0000"
tmp_hole_perimetro[1][43] = 0'-0.0000"
tmp_hole_perimetro[1][44] = 0'-0.0000"
tmp_hole_perimetro[1][45] = 0'-0.0000"
tmp_hole_perimetro[1][46] = 0'-0.0000"
tmp_hole_perimetro[1][47] = 0'-0.0000"
tmp_hole_perimetro[1][48] = 0'-0.0000"
tmp_hole_perimetro[1][49] = 0'-0.0000"
tmp_hole_perimetro[1][50] = 0'-0.0000"
tmp_hole_perimetro[1][51] = 0'-0.0000"
tmp_hole_perimetro[1][52] = 0'-0.0000"
tmp_hole_perimetro[1][53] = 0'-0.0000"
tmp_hole_perimetro[1][54] = 0'-0.0000"
tmp_hole_perimetro[1][55] = 0'-0.0000"
tmp_hole_perimetro[1][56] = 0'-0.0000"
tmp_hole_perimetro[1][57] = 0'-0.0000"
tmp_hole_perimetro[1][58] = 0'-0.0000"
tmp_hole_perimetro[1][59] = 0'-0.0000"
tmp_hole_perimetro[1][60] = 0'-0.0000"
tmp_hole_perimetro[1][61] = 0'-0.0000"
tmp_hole_perimetro[1][62] = 0'-0.0000"
tmp_hole_perimetro[1][63] = 0'-0.0000"
tmp_hole_perimetro[1][64] = 0'-0.0000"
tmp_hole_perimetro[1][65] = 0'-0.0000"
tmp_hole_perimetro[1][66] = 0'-0.0000"
tmp_hole_perimetro[1][67] = 0'-0.0000"
tmp_hole_perimetro[1][68] = 0'-0.0000"
tmp_hole_perimetro[1][69] = 0'-0.0000"
tmp_hole_perimetro[1][70] = 0'-0.0000"
tmp_hole_perimetro[1][71] = 0'-0.0000"
tmp_hole_perimetro[1][72] = 0'-0.0000"
tmp_hole_perimetro[1][73] = 0'-0.0000"
tmp_hole_perimetro[1][74] = 0'-0.0000"
tmp_hole_perimetro[1][75] = 0'-0.0000"
tmp_hole_perimetro[1][76] = 0'-0.0000"
tmp_hole_perimetro[1][77] = 0'-0.0000"
tmp_hole_perimetro[1][78] = 0'-0.0000"
tmp_hole_perimetro[1][79] = 0'-0.0000"
tmp_hole_perimetro[1][80] = 0'-0.0000"
tmp_hole_perimetro[2][1] = 0'-0.0000"
tmp_hole_perimetro[2][2] = 0'-0.0000"
tmp_hole_perimetro[2][3] = 0'-0.0000"
tmp_hole_perimetro[2][4] = 0'-0.0000"
tmp_hole_perimetro[2][5] = 0'-0.0000"
tmp_hole_perimetro[2][6] = 0'-0.0000"
tmp_hole_perimetro[2][7] = 0'-0.0000"
tmp_hole_perimetro[2][8] = 0'-0.0000"
tmp_hole_perimetro[2][9] = 0'-0.0000"
tmp_hole_perimetro[2][10] = 0'-0.0000"
tmp_hole_perimetro[2][11] = 0'-0.0000"
tmp_hole_perimetro[2][12] = 0'-0.0000"
tmp_hole_perimetro[2][13] = 0'-0.0000"
tmp_hole_perimetro[2][14] = 0'-0.0000"
tmp_hole_perimetro[2][15] = 0'-0.0000"
tmp_hole_perimetro[2][16] = 0'-0.0000"
tmp_hole_perimetro[2][17] = 0'-0.0000"
tmp_hole_perimetro[2][18] = 0'-0.0000"
tmp_hole_perimetro[2][19] = 0'-0.0000"
tmp_hole_perimetro[2][20] = 0'-0.0000"
tmp_hole_perimetro[2][21] = 0'-0.0000"
tmp_hole_perimetro[2][22] = 0'-0.0000"
tmp_hole_perimetro[2][23] = 0'-0.0000"
tmp_hole_perimetro[2][24] = 0'-0.0000"
tmp_hole_perimetro[2][25] = 0'-0.0000"
tmp_hole_perimetro[2][26] = 0'-0.0000"
tmp_hole_perimetro[2][27] = 0'-0.0000"
tmp_hole_perimetro[2][28] = 0'-0.0000"
tmp_hole_perimetro[2][29] = 0'-0.0000"
tmp_hole_perimetro[2][30] = 0'-0.0000"
tmp_hole_perimetro[2][31] = 0'-0.0000"
tmp_hole_perimetro[2][32] = 0'-0.0000"
tmp_hole_perimetro[2][33] = 0'-0.0000"
tmp_hole_perimetro[2][34] = 0'-0.0000"
tmp_hole_perimetro[2][35] = 0'-0.0000"
tmp_hole_perimetro[2][36] = 0'-0.0000"
tmp_hole_perimetro[2][37] = 0'-0.0000"
tmp_hole_perimetro[2][38] = 0'-0.0000"
tmp_hole_perimetro[2][39] = 0'-0.0000"
tmp_hole_perimetro[2][40] = 0'-0.0000"
tmp_hole_perimetro[2][41] = 0'-0.0000"
tmp_hole_perimetro[2][42] = 0'-0.0000"
tmp_hole_perimetro[2][43] = 0'-0.0000"
tmp_hole_perimetro[2][44] = 0'-0.0000"
tmp_hole_perimetro[2][45] = 0'-0.0000"
tmp_hole_perimetro[2][46] = 0'-0.0000"
tmp_hole_perimetro[2][47] = 0'-0.0000"
tmp_hole_perimetro[2][48] = 0'-0.0000"
tmp_hole_perimetro[2][49] = 0'-0.0000"
tmp_hole_perimetro[2][50] = 0'-0.0000"
tmp_hole_perimetro[2][51] = 0'-0.0000"
tmp_hole_perimetro[2][52] = 0'-0.0000"
tmp_hole_perimetro[2][53] = 0'-0.0000"
tmp_hole_perimetro[2][54] = 0'-0.0000"
tmp_hole_perimetro[2][55] = 0'-0.0000"
tmp_hole_perimetro[2][56] = 0'-0.0000"
tmp_hole_perimetro[2][57] = 0'-0.0000"
tmp_hole_perimetro[2][58] = 0'-0.0000"
tmp_hole_perimetro[2][59] = 0'-0.0000"
tmp_hole_perimetro[2][60] = 0'-0.0000"
tmp_hole_perimetro[2][61] = 0'-0.0000"
tmp_hole_perimetro[2][62] = 0'-0.0000"
tmp_hole_perimetro[2][63] = 0'-0.0000"
tmp_hole_perimetro[2][64] = 0'-0.0000"
tmp_hole_perimetro[2][65] = 0'-0.0000"
tmp_hole_perimetro[2][66] = 0'-0.0000"
tmp_hole_perimetro[2][67] = 0'-0.0000"
tmp_hole_perimetro[2][68] = 0'-0.0000"
tmp_hole_perimetro[2][69] = 0'-0.0000"
tmp_hole_perimetro[2][70] = 0'-0.0000"
tmp_hole_perimetro[2][71] = 0'-0.0000"
tmp_hole_perimetro[2][72] = 0'-0.0000"
tmp_hole_perimetro[2][73] = 0'-0.0000"
tmp_hole_perimetro[2][74] = 0'-0.0000"
tmp_hole_perimetro[2][75] = 0'-0.0000"
tmp_hole_perimetro[2][76] = 0'-0.0000"
tmp_hole_perimetro[2][77] = 0'-0.0000"
tmp_hole_perimetro[2][78] = 0'-0.0000"
tmp_hole_perimetro[2][79] = 0'-0.0000"
tmp_hole_perimetro[2][80] = 0'-0.0000"
tmp_hole_perimetro[3][1] = 0'-0.0000"
tmp_hole_perimetro[3][2] = 0'-0.0000"
tmp_hole_perimetro[3][3] = 0'-0.0000"
tmp_hole_perimetro[3][4] = 0'-0.0000"
tmp_hole_perimetro[3][5] = 0'-0.0000"
tmp_hole_perimetro[3][6] = 0'-0.0000"
tmp_hole_perimetro[3][7] = 0'-0.0000"
tmp_hole_perimetro[3][8] = 0'-0.0000"
tmp_hole_perimetro[3][9] = 0'-0.0000"
tmp_hole_perimetro[3][10] = 0'-0.0000"
tmp_hole_perimetro[3][11] = 0'-0.0000"
tmp_hole_perimetro[3][12] = 0'-0.0000"
tmp_hole_perimetro[3][13] = 0'-0.0000"
tmp_hole_perimetro[3][14] = 0'-0.0000"
tmp_hole_perimetro[3][15] = 0'-0.0000"
tmp_hole_perimetro[3][16] = 0'-0.0000"
tmp_hole_perimetro[3][17] = 0'-0.0000"
tmp_hole_perimetro[3][18] = 0'-0.0000"
tmp_hole_perimetro[3][19] = 0'-0.0000"
tmp_hole_perimetro[3][20] = 0'-0.0000"
tmp_hole_perimetro[3][21] = 0'-0.0000"
tmp_hole_perimetro[3][22] = 0'-0.0000"
tmp_hole_perimetro[3][23] = 0'-0.0000"
tmp_hole_perimetro[3][24] = 0'-0.0000"
tmp_hole_perimetro[3][25] = 0'-0.0000"
tmp_hole_perimetro[3][26] = 0'-0.0000"
tmp_hole_perimetro[3][27] = 0'-0.0000"
tmp_hole_perimetro[3][28] = 0'-0.0000"
tmp_hole_perimetro[3][29] = 0'-0.0000"
tmp_hole_perimetro[3][30] = 0'-0.0000"
tmp_hole_perimetro[3][31] = 0'-0.0000"
tmp_hole_perimetro[3][32] = 0'-0.0000"
tmp_hole_perimetro[3][33] = 0'-0.0000"
tmp_hole_perimetro[3][34] = 0'-0.0000"
tmp_hole_perimetro[3][35] = 0'-0.0000"
tmp_hole_perimetro[3][36] = 0'-0.0000"
tmp_hole_perimetro[3][37] = 0'-0.0000"
tmp_hole_perimetro[3][38] = 0'-0.0000"
tmp_hole_perimetro[3][39] = 0'-0.0000"
tmp_hole_perimetro[3][40] = 0'-0.0000"
tmp_hole_perimetro[3][41] = 0'-0.0000"
tmp_hole_perimetro[3][42] = 0'-0.0000"
tmp_hole_perimetro[3][43] = 0'-0.0000"
tmp_hole_perimetro[3][44] = 0'-0.0000"
tmp_hole_perimetro[3][45] = 0'-0.0000"
tmp_hole_perimetro[3][46] = 0'-0.0000"
tmp_hole_perimetro[3][47] = 0'-0.0000"
tmp_hole_perimetro[3][48] = 0'-0.0000"
tmp_hole_perimetro[3][49] = 0'-0.0000"
tmp_hole_perimetro[3][50] = 0'-0.0000"
tmp_hole_perimetro[3][51] = 0'-0.0000"
tmp_hole_perimetro[3][52] = 0'-0.0000"
tmp_hole_perimetro[3][53] = 0'-0.0000"
tmp_hole_perimetro[3][54] = 0'-0.0000"
tmp_hole_perimetro[3][55] = 0'-0.0000"
tmp_hole_perimetro[3][56] = 0'-0.0000"
tmp_hole_perimetro[3][57] = 0'-0.0000"
tmp_hole_perimetro[3][58] = 0'-0.0000"
tmp_hole_perimetro[3][59] = 0'-0.0000"
tmp_hole_perimetro[3][60] = 0'-0.0000"
tmp_hole_perimetro[3][61] = 0'-0.0000"
tmp_hole_perimetro[3][62] = 0'-0.0000"
tmp_hole_perimetro[3][63] = 0'-0.0000"
tmp_hole_perimetro[3][64] = 0'-0.0000"
tmp_hole_perimetro[3][65] = 0'-0.0000"
tmp_hole_perimetro[3][66] = 0'-0.0000"
tmp_hole_perimetro[3][67] = 0'-0.0000"
tmp_hole_perimetro[3][68] = 0'-0.0000"
tmp_hole_perimetro[3][69] = 0'-0.0000"
tmp_hole_perimetro[3][70] = 0'-0.0000"
tmp_hole_perimetro[3][71] = 0'-0.0000"
tmp_hole_perimetro[3][72] = 0'-0.0000"
tmp_hole_perimetro[3][73] = 0'-0.0000"
tmp_hole_perimetro[3][74] = 0'-0.0000"
tmp_hole_perimetro[3][75] = 0'-0.0000"
tmp_hole_perimetro[3][76] = 0'-0.0000"
tmp_hole_perimetro[3][77] = 0'-0.0000"
tmp_hole_perimetro[3][78] = 0'-0.0000"
tmp_hole_perimetro[3][79] = 0'-0.0000"
tmp_hole_perimetro[3][80] = 0'-0.0000"
tmp_hole_perimetro[4][1] = 0'-0.0000"
tmp_hole_perimetro[4][2] = 0'-0.0000"
tmp_hole_perimetro[4][3] = 0'-0.0000"
tmp_hole_perimetro[4][4] = 0'-0.0000"
tmp_hole_perimetro[4][5] = 0'-0.0000"
tmp_hole_perimetro[4][6] = 0'-0.0000"
tmp_hole_perimetro[4][7] = 0'-0.0000"
tmp_hole_perimetro[4][8] = 0'-0.0000"
tmp_hole_perimetro[4][9] = 0'-0.0000"
tmp_hole_perimetro[4][10] = 0'-0.0000"
tmp_hole_perimetro[4][11] = 0'-0.0000"
tmp_hole_perimetro[4][12] = 0'-0.0000"
tmp_hole_perimetro[4][13] = 0'-0.0000"
tmp_hole_perimetro[4][14] = 0'-0.0000"
tmp_hole_perimetro[4][15] = 0'-0.0000"
tmp_hole_perimetro[4][16] = 0'-0.0000"
tmp_hole_perimetro[4][17] = 0'-0.0000"
tmp_hole_perimetro[4][18] = 0'-0.0000"
tmp_hole_perimetro[4][19] = 0'-0.0000"
tmp_hole_perimetro[4][20] = 0'-0.0000"
tmp_hole_perimetro[4][21] = 0'-0.0000"
tmp_hole_perimetro[4][22] = 0'-0.0000"
tmp_hole_perimetro[4][23] = 0'-0.0000"
tmp_hole_perimetro[4][24] = 0'-0.0000"
tmp_hole_perimetro[4][25] = 0'-0.0000"
tmp_hole_perimetro[4][26] = 0'-0.0000"
tmp_hole_perimetro[4][27] = 0'-0.0000"
tmp_hole_perimetro[4][28] = 0'-0.0000"
tmp_hole_perimetro[4][29] = 0'-0.0000"
tmp_hole_perimetro[4][30] = 0'-0.0000"
tmp_hole_perimetro[4][31] = 0'-0.0000"
tmp_hole_perimetro[4][32] = 0'-0.0000"
tmp_hole_perimetro[4][33] = 0'-0.0000"
tmp_hole_perimetro[4][34] = 0'-0.0000"
tmp_hole_perimetro[4][35] = 0'-0.0000"
tmp_hole_perimetro[4][36] = 0'-0.0000"
tmp_hole_perimetro[4][37] = 0'-0.0000"
tmp_hole_perimetro[4][38] = 0'-0.0000"
tmp_hole_perimetro[4][39] = 0'-0.0000"
tmp_hole_perimetro[4][40] = 0'-0.0000"
tmp_hole_perimetro[4][41] = 0'-0.0000"
tmp_hole_perimetro[4][42] = 0'-0.0000"
tmp_hole_perimetro[4][43] = 0'-0.0000"
tmp_hole_perimetro[4][44] = 0'-0.0000"
tmp_hole_perimetro[4][45] = 0'-0.0000"
tmp_hole_perimetro[4][46] = 0'-0.0000"
tmp_hole_perimetro[4][47] = 0'-0.0000"
tmp_hole_perimetro[4][48] = 0'-0.0000"
tmp_hole_perimetro[4][49] = 0'-0.0000"
tmp_hole_perimetro[4][50] = 0'-0.0000"
tmp_hole_perimetro[4][51] = 0'-0.0000"
tmp_hole_perimetro[4][52] = 0'-0.0000"
tmp_hole_perimetro[4][53] = 0'-0.0000"
tmp_hole_perimetro[4][54] = 0'-0.0000"
tmp_hole_perimetro[4][55] = 0'-0.0000"
tmp_hole_perimetro[4][56] = 0'-0.0000"
tmp_hole_perimetro[4][57] = 0'-0.0000"
tmp_hole_perimetro[4][58] = 0'-0.0000"
tmp_hole_perimetro[4][59] = 0'-0.0000"
tmp_hole_perimetro[4][60] = 0'-0.0000"
tmp_hole_perimetro[4][61] = 0'-0.0000"
tmp_hole_perimetro[4][62] = 0'-0.0000"
tmp_hole_perimetro[4][63] = 0'-0.0000"
tmp_hole_perimetro[4][64] = 0'-0.0000"
tmp_hole_perimetro[4][65] = 0'-0.0000"
tmp_hole_perimetro[4][66] = 0'-0.0000"
tmp_hole_perimetro[4][67] = 0'-0.0000"
tmp_hole_perimetro[4][68] = 0'-0.0000"
tmp_hole_perimetro[4][69] = 0'-0.0000"
tmp_hole_perimetro[4][70] = 0'-0.0000"
tmp_hole_perimetro[4][71] = 0'-0.0000"
tmp_hole_perimetro[4][72] = 0'-0.0000"
tmp_hole_perimetro[4][73] = 0'-0.0000"
tmp_hole_perimetro[4][74] = 0'-0.0000"
tmp_hole_perimetro[4][75] = 0'-0.0000"
tmp_hole_perimetro[4][76] = 0'-0.0000"
tmp_hole_perimetro[4][77] = 0'-0.0000"
tmp_hole_perimetro[4][78] = 0'-0.0000"
tmp_hole_perimetro[4][79] = 0'-0.0000"
tmp_hole_perimetro[4][80] = 0'-0.0000"
tmp_hole_perimetro[5][1] = 0'-0.0000"
tmp_hole_perimetro[5][2] = 0'-0.0000"
tmp_hole_perimetro[5][3] = 0'-0.0000"
tmp_hole_perimetro[5][4] = 0'-0.0000"
tmp_hole_perimetro[5][5] = 0'-0.0000"
tmp_hole_perimetro[5][6] = 0'-0.0000"
tmp_hole_perimetro[5][7] = 0'-0.0000"
tmp_hole_perimetro[5][8] = 0'-0.0000"
tmp_hole_perimetro[5][9] = 0'-0.0000"
tmp_hole_perimetro[5][10] = 0'-0.0000"
tmp_hole_perimetro[5][11] = 0'-0.0000"
tmp_hole_perimetro[5][12] = 0'-0.0000"
tmp_hole_perimetro[5][13] = 0'-0.0000"
tmp_hole_perimetro[5][14] = 0'-0.0000"
tmp_hole_perimetro[5][15] = 0'-0.0000"
tmp_hole_perimetro[5][16] = 0'-0.0000"
tmp_hole_perimetro[5][17] = 0'-0.0000"
tmp_hole_perimetro[5][18] = 0'-0.0000"
tmp_hole_perimetro[5][19] = 0'-0.0000"
tmp_hole_perimetro[5][20] = 0'-0.0000"
tmp_hole_perimetro[5][21] = 0'-0.0000"
tmp_hole_perimetro[5][22] = 0'-0.0000"
tmp_hole_perimetro[5][23] = 0'-0.0000"
tmp_hole_perimetro[5][24] = 0'-0.0000"
tmp_hole_perimetro[5][25] = 0'-0.0000"
tmp_hole_perimetro[5][26] = 0'-0.0000"
tmp_hole_perimetro[5][27] = 0'-0.0000"
tmp_hole_perimetro[5][28] = 0'-0.0000"
tmp_hole_perimetro[5][29] = 0'-0.0000"
tmp_hole_perimetro[5][30] = 0'-0.0000"
tmp_hole_perimetro[5][31] = 0'-0.0000"
tmp_hole_perimetro[5][32] = 0'-0.0000"
tmp_hole_perimetro[5][33] = 0'-0.0000"
tmp_hole_perimetro[5][34] = 0'-0.0000"
tmp_hole_perimetro[5][35] = 0'-0.0000"
tmp_hole_perimetro[5][36] = 0'-0.0000"
tmp_hole_perimetro[5][37] = 0'-0.0000"
tmp_hole_perimetro[5][38] = 0'-0.0000"
tmp_hole_perimetro[5][39] = 0'-0.0000"
tmp_hole_perimetro[5][40] = 0'-0.0000"
tmp_hole_perimetro[5][41] = 0'-0.0000"
tmp_hole_perimetro[5][42] = 0'-0.0000"
tmp_hole_perimetro[5][43] = 0'-0.0000"
tmp_hole_perimetro[5][44] = 0'-0.0000"
tmp_hole_perimetro[5][45] = 0'-0.0000"
tmp_hole_perimetro[5][46] = 0'-0.0000"
tmp_hole_perimetro[5][47] = 0'-0.0000"
tmp_hole_perimetro[5][48] = 0'-0.0000"
tmp_hole_perimetro[5][49] = 0'-0.0000"
tmp_hole_perimetro[5][50] = 0'-0.0000"
tmp_hole_perimetro[5][51] = 0'-0.0000"
tmp_hole_perimetro[5][52] = 0'-0.0000"
tmp_hole_perimetro[5][53] = 0'-0.0000"
tmp_hole_perimetro[5][54] = 0'-0.0000"
tmp_hole_perimetro[5][55] = 0'-0.0000"
tmp_hole_perimetro[5][56] = 0'-0.0000"
tmp_hole_perimetro[5][57] = 0'-0.0000"
tmp_hole_perimetro[5][58] = 0'-0.0000"
tmp_hole_perimetro[5][59] = 0'-0.0000"
tmp_hole_perimetro[5][60] = 0'-0.0000"
tmp_hole_perimetro[5][61] = 0'-0.0000"
tmp_hole_perimetro[5][62] = 0'-0.0000"
tmp_hole_perimetro[5][63] = 0'-0.0000"
tmp_hole_perimetro[5][64] = 0'-0.0000"
tmp_hole_perimetro[5][65] = 0'-0.0000"
tmp_hole_perimetro[5][66] = 0'-0.0000"
tmp_hole_perimetro[5][67] = 0'-0.0000"
tmp_hole_perimetro[5][68] = 0'-0.0000"
tmp_hole_perimetro[5][69] = 0'-0.0000"
tmp_hole_perimetro[5][70] = 0'-0.0000"
tmp_hole_perimetro[5][71] = 0'-0.0000"
tmp_hole_perimetro[5][72] = 0'-0.0000"
tmp_hole_perimetro[5][73] = 0'-0.0000"
tmp_hole_perimetro[5][74] = 0'-0.0000"
tmp_hole_perimetro[5][75] = 0'-0.0000"
tmp_hole_perimetro[5][76] = 0'-0.0000"
tmp_hole_perimetro[5][77] = 0'-0.0000"
tmp_hole_perimetro[5][78] = 0'-0.0000"
tmp_hole_perimetro[5][79] = 0'-0.0000"
tmp_hole_perimetro[5][80] = 0'-0.0000"
tmp_hole_perimetro[6][1] = 0'-0.0000"
tmp_hole_perimetro[6][2] = 0'-0.0000"
tmp_hole_perimetro[6][3] = 0'-0.0000"
tmp_hole_perimetro[6][4] = 0'-0.0000"
tmp_hole_perimetro[6][5] = 0'-0.0000"
tmp_hole_perimetro[6][6] = 0'-0.0000"
tmp_hole_perimetro[6][7] = 0'-0.0000"
tmp_hole_perimetro[6][8] = 0'-0.0000"
tmp_hole_perimetro[6][9] = 0'-0.0000"
tmp_hole_perimetro[6][10] = 0'-0.0000"
tmp_hole_perimetro[6][11] = 0'-0.0000"
tmp_hole_perimetro[6][12] = 0'-0.0000"
tmp_hole_perimetro[6][13] = 0'-0.0000"
tmp_hole_perimetro[6][14] = 0'-0.0000"
tmp_hole_perimetro[6][15] = 0'-0.0000"
tmp_hole_perimetro[6][16] = 0'-0.0000"
tmp_hole_perimetro[6][17] = 0'-0.0000"
tmp_hole_perimetro[6][18] = 0'-0.0000"
tmp_hole_perimetro[6][19] = 0'-0.0000"
tmp_hole_perimetro[6][20] = 0'-0.0000"
tmp_hole_perimetro[6][21] = 0'-0.0000"
tmp_hole_perimetro[6][22] = 0'-0.0000"
tmp_hole_perimetro[6][23] = 0'-0.0000"
tmp_hole_perimetro[6][24] = 0'-0.0000"
tmp_hole_perimetro[6][25] = 0'-0.0000"
tmp_hole_perimetro[6][26] = 0'-0.0000"
tmp_hole_perimetro[6][27] = 0'-0.0000"
tmp_hole_perimetro[6][28] = 0'-0.0000"
tmp_hole_perimetro[6][29] = 0'-0.0000"
tmp_hole_perimetro[6][30] = 0'-0.0000"
tmp_hole_perimetro[6][31] = 0'-0.0000"
tmp_hole_perimetro[6][32] = 0'-0.0000"
tmp_hole_perimetro[6][33] = 0'-0.0000"
tmp_hole_perimetro[6][34] = 0'-0.0000"
tmp_hole_perimetro[6][35] = 0'-0.0000"
tmp_hole_perimetro[6][36] = 0'-0.0000"
tmp_hole_perimetro[6][37] = 0'-0.0000"
tmp_hole_perimetro[6][38] = 0'-0.0000"
tmp_hole_perimetro[6][39] = 0'-0.0000"
tmp_hole_perimetro[6][40] = 0'-0.0000"
tmp_hole_perimetro[6][41] = 0'-0.0000"
tmp_hole_perimetro[6][42] = 0'-0.0000"
tmp_hole_perimetro[6][43] = 0'-0.0000"
tmp_hole_perimetro[6][44] = 0'-0.0000"
tmp_hole_perimetro[6][45] = 0'-0.0000"
tmp_hole_perimetro[6][46] = 0'-0.0000"
tmp_hole_perimetro[6][47] = 0'-0.0000"
tmp_hole_perimetro[6][48] = 0'-0.0000"
tmp_hole_perimetro[6][49] = 0'-0.0000"
tmp_hole_perimetro[6][50] = 0'-0.0000"
tmp_hole_perimetro[6][51] = 0'-0.0000"
tmp_hole_perimetro[6][52] = 0'-0.0000"
tmp_hole_perimetro[6][53] = 0'-0.0000"
tmp_hole_perimetro[6][54] = 0'-0.0000"
tmp_hole_perimetro[6][55] = 0'-0.0000"
tmp_hole_perimetro[6][56] = 0'-0.0000"
tmp_hole_perimetro[6][57] = 0'-0.0000"
tmp_hole_perimetro[6][58] = 0'-0.0000"
tmp_hole_perimetro[6][59] = 0'-0.0000"
tmp_hole_perimetro[6][60] = 0'-0.0000"
tmp_hole_perimetro[6][61] = 0'-0.0000"
tmp_hole_perimetro[6][62] = 0'-0.0000"
tmp_hole_perimetro[6][63] = 0'-0.0000"
tmp_hole_perimetro[6][64] = 0'-0.0000"
tmp_hole_perimetro[6][65] = 0'-0.0000"
tmp_hole_perimetro[6][66] = 0'-0.0000"
tmp_hole_perimetro[6][67] = 0'-0.0000"
tmp_hole_perimetro[6][68] = 0'-0.0000"
tmp_hole_perimetro[6][69] = 0'-0.0000"
tmp_hole_perimetro[6][70] = 0'-0.0000"
tmp_hole_perimetro[6][71] = 0'-0.0000"
tmp_hole_perimetro[6][72] = 0'-0.0000"
tmp_hole_perimetro[6][73] = 0'-0.0000"
tmp_hole_perimetro[6][74] = 0'-0.0000"
tmp_hole_perimetro[6][75] = 0'-0.0000"
tmp_hole_perimetro[6][76] = 0'-0.0000"
tmp_hole_perimetro[6][77] = 0'-0.0000"
tmp_hole_perimetro[6][78] = 0'-0.0000"
tmp_hole_perimetro[6][79] = 0'-0.0000"
tmp_hole_perimetro[6][80] = 0'-0.0000"
tmp_hole_perimetro[7][1] = 0'-0.0000"
tmp_hole_perimetro[7][2] = 0'-0.0000"
tmp_hole_perimetro[7][3] = 0'-0.0000"
tmp_hole_perimetro[7][4] = 0'-0.0000"
tmp_hole_perimetro[7][5] = 0'-0.0000"
tmp_hole_perimetro[7][6] = 0'-0.0000"
tmp_hole_perimetro[7][7] = 0'-0.0000"
tmp_hole_perimetro[7][8] = 0'-0.0000"
tmp_hole_perimetro[7][9] = 0'-0.0000"
tmp_hole_perimetro[7][10] = 0'-0.0000"
tmp_hole_perimetro[7][11] = 0'-0.0000"
tmp_hole_perimetro[7][12] = 0'-0.0000"
tmp_hole_perimetro[7][13] = 0'-0.0000"
tmp_hole_perimetro[7][14] = 0'-0.0000"
tmp_hole_perimetro[7][15] = 0'-0.0000"
tmp_hole_perimetro[7][16] = 0'-0.0000"
tmp_hole_perimetro[7][17] = 0'-0.0000"
tmp_hole_perimetro[7][18] = 0'-0.0000"
tmp_hole_perimetro[7][19] = 0'-0.0000"
tmp_hole_perimetro[7][20] = 0'-0.0000"
tmp_hole_perimetro[7][21] = 0'-0.0000"
tmp_hole_perimetro[7][22] = 0'-0.0000"
tmp_hole_perimetro[7][23] = 0'-0.0000"
tmp_hole_perimetro[7][24] = 0'-0.0000"
tmp_hole_perimetro[7][25] = 0'-0.0000"
tmp_hole_perimetro[7][26] = 0'-0.0000"
tmp_hole_perimetro[7][27] = 0'-0.0000"
tmp_hole_perimetro[7][28] = 0'-0.0000"
tmp_hole_perimetro[7][29] = 0'-0.0000"
tmp_hole_perimetro[7][30] = 0'-0.0000"
tmp_hole_perimetro[7][31] = 0'-0.0000"
tmp_hole_perimetro[7][32] = 0'-0.0000"
tmp_hole_perimetro[7][33] = 0'-0.0000"
tmp_hole_perimetro[7][34] = 0'-0.0000"
tmp_hole_perimetro[7][35] = 0'-0.0000"
tmp_hole_perimetro[7][36] = 0'-0.0000"
tmp_hole_perimetro[7][37] = 0'-0.0000"
tmp_hole_perimetro[7][38] = 0'-0.0000"
tmp_hole_perimetro[7][39] = 0'-0.0000"
tmp_hole_perimetro[7][40] = 0'-0.0000"
tmp_hole_perimetro[7][41] = 0'-0.0000"
tmp_hole_perimetro[7][42] = 0'-0.0000"
tmp_hole_perimetro[7][43] = 0'-0.0000"
tmp_hole_perimetro[7][44] = 0'-0.0000"
tmp_hole_perimetro[7][45] = 0'-0.0000"
tmp_hole_perimetro[7][46] = 0'-0.0000"
tmp_hole_perimetro[7][47] = 0'-0.0000"
tmp_hole_perimetro[7][48] = 0'-0.0000"
tmp_hole_perimetro[7][49] = 0'-0.0000"
tmp_hole_perimetro[7][50] = 0'-0.0000"
tmp_hole_perimetro[7][51] = 0'-0.0000"
tmp_hole_perimetro[7][52] = 0'-0.0000"
tmp_hole_perimetro[7][53] = 0'-0.0000"
tmp_hole_perimetro[7][54] = 0'-0.0000"
tmp_hole_perimetro[7][55] = 0'-0.0000"
tmp_hole_perimetro[7][56] = 0'-0.0000"
tmp_hole_perimetro[7][57] = 0'-0.0000"
tmp_hole_perimetro[7][58] = 0'-0.0000"
tmp_hole_perimetro[7][59] = 0'-0.0000"
tmp_hole_perimetro[7][60] = 0'-0.0000"
tmp_hole_perimetro[7][61] = 0'-0.0000"
tmp_hole_perimetro[7][62] = 0'-0.0000"
tmp_hole_perimetro[7][63] = 0'-0.0000"
tmp_hole_perimetro[7][64] = 0'-0.0000"
tmp_hole_perimetro[7][65] = 0'-0.0000"
tmp_hole_perimetro[7][66] = 0'-0.0000"
tmp_hole_perimetro[7][67] = 0'-0.0000"
tmp_hole_perimetro[7][68] = 0'-0.0000"
tmp_hole_perimetro[7][69] = 0'-0.0000"
tmp_hole_perimetro[7][70] = 0'-0.0000"
tmp_hole_perimetro[7][71] = 0'-0.0000"
tmp_hole_perimetro[7][72] = 0'-0.0000"
tmp_hole_perimetro[7][73] = 0'-0.0000"
tmp_hole_perimetro[7][74] = 0'-0.0000"
tmp_hole_perimetro[7][75] = 0'-0.0000"
tmp_hole_perimetro[7][76] = 0'-0.0000"
tmp_hole_perimetro[7][77] = 0'-0.0000"
tmp_hole_perimetro[7][78] = 0'-0.0000"
tmp_hole_perimetro[7][79] = 0'-0.0000"
tmp_hole_perimetro[7][80] = 0'-0.0000"
tmp_hole_perimetro[8][1] = 0'-0.0000"
tmp_hole_perimetro[8][2] = 0'-0.0000"
tmp_hole_perimetro[8][3] = 0'-0.0000"
tmp_hole_perimetro[8][4] = 0'-0.0000"
tmp_hole_perimetro[8][5] = 0'-0.0000"
tmp_hole_perimetro[8][6] = 0'-0.0000"
tmp_hole_perimetro[8][7] = 0'-0.0000"
tmp_hole_perimetro[8][8] = 0'-0.0000"
tmp_hole_perimetro[8][9] = 0'-0.0000"
tmp_hole_perimetro[8][10] = 0'-0.0000"
tmp_hole_perimetro[8][11] = 0'-0.0000"
tmp_hole_perimetro[8][12] = 0'-0.0000"
tmp_hole_perimetro[8][13] = 0'-0.0000"
tmp_hole_perimetro[8][14] = 0'-0.0000"
tmp_hole_perimetro[8][15] = 0'-0.0000"
tmp_hole_perimetro[8][16] = 0'-0.0000"
tmp_hole_perimetro[8][17] = 0'-0.0000"
tmp_hole_perimetro[8][18] = 0'-0.0000"
tmp_hole_perimetro[8][19] = 0'-0.0000"
tmp_hole_perimetro[8][20] = 0'-0.0000"
tmp_hole_perimetro[8][21] = 0'-0.0000"
tmp_hole_perimetro[8][22] = 0'-0.0000"
tmp_hole_perimetro[8][23] = 0'-0.0000"
tmp_hole_perimetro[8][24] = 0'-0.0000"
tmp_hole_perimetro[8][25] = 0'-0.0000"
tmp_hole_perimetro[8][26] = 0'-0.0000"
tmp_hole_perimetro[8][27] = 0'-0.0000"
tmp_hole_perimetro[8][28] = 0'-0.0000"
tmp_hole_perimetro[8][29] = 0'-0.0000"
tmp_hole_perimetro[8][30] = 0'-0.0000"
tmp_hole_perimetro[8][31] = 0'-0.0000"
tmp_hole_perimetro[8][32] = 0'-0.0000"
tmp_hole_perimetro[8][33] = 0'-0.0000"
tmp_hole_perimetro[8][34] = 0'-0.0000"
tmp_hole_perimetro[8][35] = 0'-0.0000"
tmp_hole_perimetro[8][36] = 0'-0.0000"
tmp_hole_perimetro[8][37] = 0'-0.0000"
tmp_hole_perimetro[8][38] = 0'-0.0000"
tmp_hole_perimetro[8][39] = 0'-0.0000"
tmp_hole_perimetro[8][40] = 0'-0.0000"
tmp_hole_perimetro[8][41] = 0'-0.0000"
tmp_hole_perimetro[8][42] = 0'-0.0000"
tmp_hole_perimetro[8][43] = 0'-0.0000"
tmp_hole_perimetro[8][44] = 0'-0.0000"
tmp_hole_perimetro[8][45] = 0'-0.0000"
tmp_hole_perimetro[8][46] = 0'-0.0000"
tmp_hole_perimetro[8][47] = 0'-0.0000"
tmp_hole_perimetro[8][48] = 0'-0.0000"
tmp_hole_perimetro[8][49] = 0'-0.0000"
tmp_hole_perimetro[8][50] = 0'-0.0000"
tmp_hole_perimetro[8][51] = 0'-0.0000"
tmp_hole_perimetro[8][52] = 0'-0.0000"
tmp_hole_perimetro[8][53] = 0'-0.0000"
tmp_hole_perimetro[8][54] = 0'-0.0000"
tmp_hole_perimetro[8][55] = 0'-0.0000"
tmp_hole_perimetro[8][56] = 0'-0.0000"
tmp_hole_perimetro[8][57] = 0'-0.0000"
tmp_hole_perimetro[8][58] = 0'-0.0000"
tmp_hole_perimetro[8][59] = 0'-0.0000"
tmp_hole_perimetro[8][60] = 0'-0.0000"
tmp_hole_perimetro[8][61] = 0'-0.0000"
tmp_hole_perimetro[8][62] = 0'-0.0000"
tmp_hole_perimetro[8][63] = 0'-0.0000"
tmp_hole_perimetro[8][64] = 0'-0.0000"
tmp_hole_perimetro[8][65] = 0'-0.0000"
tmp_hole_perimetro[8][66] = 0'-0.0000"
tmp_hole_perimetro[8][67] = 0'-0.0000"
tmp_hole_perimetro[8][68] = 0'-0.0000"
tmp_hole_perimetro[8][69] = 0'-0.0000"
tmp_hole_perimetro[8][70] = 0'-0.0000"
tmp_hole_perimetro[8][71] = 0'-0.0000"
tmp_hole_perimetro[8][72] = 0'-0.0000"
tmp_hole_perimetro[8][73] = 0'-0.0000"
tmp_hole_perimetro[8][74] = 0'-0.0000"
tmp_hole_perimetro[8][75] = 0'-0.0000"
tmp_hole_perimetro[8][76] = 0'-0.0000"
tmp_hole_perimetro[8][77] = 0'-0.0000"
tmp_hole_perimetro[8][78] = 0'-0.0000"
tmp_hole_perimetro[8][79] = 0'-0.0000"
tmp_hole_perimetro[8][80] = 0'-0.0000"
tmp_hole_perimetro[9][1] = 0'-0.0000"
tmp_hole_perimetro[9][2] = 0'-0.0000"
tmp_hole_perimetro[9][3] = 0'-0.0000"
tmp_hole_perimetro[9][4] = 0'-0.0000"
tmp_hole_perimetro[9][5] = 0'-0.0000"
tmp_hole_perimetro[9][6] = 0'-0.0000"
tmp_hole_perimetro[9][7] = 0'-0.0000"
tmp_hole_perimetro[9][8] = 0'-0.0000"
tmp_hole_perimetro[9][9] = 0'-0.0000"
tmp_hole_perimetro[9][10] = 0'-0.0000"
tmp_hole_perimetro[9][11] = 0'-0.0000"
tmp_hole_perimetro[9][12] = 0'-0.0000"
tmp_hole_perimetro[9][13] = 0'-0.0000"
tmp_hole_perimetro[9][14] = 0'-0.0000"
tmp_hole_perimetro[9][15] = 0'-0.0000"
tmp_hole_perimetro[9][16] = 0'-0.0000"
tmp_hole_perimetro[9][17] = 0'-0.0000"
tmp_hole_perimetro[9][18] = 0'-0.0000"
tmp_hole_perimetro[9][19] = 0'-0.0000"
tmp_hole_perimetro[9][20] = 0'-0.0000"
tmp_hole_perimetro[9][21] = 0'-0.0000"
tmp_hole_perimetro[9][22] = 0'-0.0000"
tmp_hole_perimetro[9][23] = 0'-0.0000"
tmp_hole_perimetro[9][24] = 0'-0.0000"
tmp_hole_perimetro[9][25] = 0'-0.0000"
tmp_hole_perimetro[9][26] = 0'-0.0000"
tmp_hole_perimetro[9][27] = 0'-0.0000"
tmp_hole_perimetro[9][28] = 0'-0.0000"
tmp_hole_perimetro[9][29] = 0'-0.0000"
tmp_hole_perimetro[9][30] = 0'-0.0000"
tmp_hole_perimetro[9][31] = 0'-0.0000"
tmp_hole_perimetro[9][32] = 0'-0.0000"
tmp_hole_perimetro[9][33] = 0'-0.0000"
tmp_hole_perimetro[9][34] = 0'-0.0000"
tmp_hole_perimetro[9][35] = 0'-0.0000"
tmp_hole_perimetro[9][36] = 0'-0.0000"
tmp_hole_perimetro[9][37] = 0'-0.0000"
tmp_hole_perimetro[9][38] = 0'-0.0000"
tmp_hole_perimetro[9][39] = 0'-0.0000"
tmp_hole_perimetro[9][40] = 0'-0.0000"
tmp_hole_perimetro[9][41] = 0'-0.0000"
tmp_hole_perimetro[9][42] = 0'-0.0000"
tmp_hole_perimetro[9][43] = 0'-0.0000"
tmp_hole_perimetro[9][44] = 0'-0.0000"
tmp_hole_perimetro[9][45] = 0'-0.0000"
tmp_hole_perimetro[9][46] = 0'-0.0000"
tmp_hole_perimetro[9][47] = 0'-0.0000"
tmp_hole_perimetro[9][48] = 0'-0.0000"
tmp_hole_perimetro[9][49] = 0'-0.0000"
tmp_hole_perimetro[9][50] = 0'-0.0000"
tmp_hole_perimetro[9][51] = 0'-0.0000"
tmp_hole_perimetro[9][52] = 0'-0.0000"
tmp_hole_perimetro[9][53] = 0'-0.0000"
tmp_hole_perimetro[9][54] = 0'-0.0000"
tmp_hole_perimetro[9][55] = 0'-0.0000"
tmp_hole_perimetro[9][56] = 0'-0.0000"
tmp_hole_perimetro[9][57] = 0'-0.0000"
tmp_hole_perimetro[9][58] = 0'-0.0000"
tmp_hole_perimetro[9][59] = 0'-0.0000"
tmp_hole_perimetro[9][60] = 0'-0.0000"
tmp_hole_perimetro[9][61] = 0'-0.0000"
tmp_hole_perimetro[9][62] = 0'-0.0000"
tmp_hole_perimetro[9][63] = 0'-0.0000"
tmp_hole_perimetro[9][64] = 0'-0.0000"
tmp_hole_perimetro[9][65] = 0'-0.0000"
tmp_hole_perimetro[9][66] = 0'-0.0000"
tmp_hole_perimetro[9][67] = 0'-0.0000"
tmp_hole_perimetro[9][68] = 0'-0.0000"
tmp_hole_perimetro[9][69] = 0'-0.0000"
tmp_hole_perimetro[9][70] = 0'-0.0000"
tmp_hole_perimetro[9][71] = 0'-0.0000"
tmp_hole_perimetro[9][72] = 0'-0.0000"
tmp_hole_perimetro[9][73] = 0'-0.0000"
tmp_hole_perimetro[9][74] = 0'-0.0000"
tmp_hole_perimetro[9][75] = 0'-0.0000"
tmp_hole_perimetro[9][76] = 0'-0.0000"
tmp_hole_perimetro[9][77] = 0'-0.0000"
tmp_hole_perimetro[9][78] = 0'-0.0000"
tmp_hole_perimetro[9][79] = 0'-0.0000"
tmp_hole_perimetro[9][80] = 0'-0.0000"
tmp_hole_perimetro[10][1] = 0'-0.0000"
tmp_hole_perimetro[10][2] = 0'-0.0000"
tmp_hole_perimetro[10][3] = 0'-0.0000"
tmp_hole_perimetro[10][4] = 0'-0.0000"
tmp_hole_perimetro[10][5] = 0'-0.0000"
tmp_hole_perimetro[10][6] = 0'-0.0000"
tmp_hole_perimetro[10][7] = 0'-0.0000"
tmp_hole_perimetro[10][8] = 0'-0.0000"
tmp_hole_perimetro[10][9] = 0'-0.0000"
tmp_hole_perimetro[10][10] = 0'-0.0000"
tmp_hole_perimetro[10][11] = 0'-0.0000"
tmp_hole_perimetro[10][12] = 0'-0.0000"
tmp_hole_perimetro[10][13] = 0'-0.0000"
tmp_hole_perimetro[10][14] = 0'-0.0000"
tmp_hole_perimetro[10][15] = 0'-0.0000"
tmp_hole_perimetro[10][16] = 0'-0.0000"
tmp_hole_perimetro[10][17] = 0'-0.0000"
tmp_hole_perimetro[10][18] = 0'-0.0000"
tmp_hole_perimetro[10][19] = 0'-0.0000"
tmp_hole_perimetro[10][20] = 0'-0.0000"
tmp_hole_perimetro[10][21] = 0'-0.0000"
tmp_hole_perimetro[10][22] = 0'-0.0000"
tmp_hole_perimetro[10][23] = 0'-0.0000"
tmp_hole_perimetro[10][24] = 0'-0.0000"
tmp_hole_perimetro[10][25] = 0'-0.0000"
tmp_hole_perimetro[10][26] = 0'-0.0000"
tmp_hole_perimetro[10][27] = 0'-0.0000"
tmp_hole_perimetro[10][28] = 0'-0.0000"
tmp_hole_perimetro[10][29] = 0'-0.0000"
tmp_hole_perimetro[10][30] = 0'-0.0000"
tmp_hole_perimetro[10][31] = 0'-0.0000"
tmp_hole_perimetro[10][32] = 0'-0.0000"
tmp_hole_perimetro[10][33] = 0'-0.0000"
tmp_hole_perimetro[10][34] = 0'-0.0000"
tmp_hole_perimetro[10][35] = 0'-0.0000"
tmp_hole_perimetro[10][36] = 0'-0.0000"
tmp_hole_perimetro[10][37] = 0'-0.0000"
tmp_hole_perimetro[10][38] = 0'-0.0000"
tmp_hole_perimetro[10][39] = 0'-0.0000"
tmp_hole_perimetro[10][40] = 0'-0.0000"
tmp_hole_perimetro[10][41] = 0'-0.0000"
tmp_hole_perimetro[10][42] = 0'-0.0000"
tmp_hole_perimetro[10][43] = 0'-0.0000"
tmp_hole_perimetro[10][44] = 0'-0.0000"
tmp_hole_perimetro[10][45] = 0'-0.0000"
tmp_hole_perimetro[10][46] = 0'-0.0000"
tmp_hole_perimetro[10][47] = 0'-0.0000"
tmp_hole_perimetro[10][48] = 0'-0.0000"
tmp_hole_perimetro[10][49] = 0'-0.0000"
tmp_hole_perimetro[10][50] = 0'-0.0000"
tmp_hole_perimetro[10][51] = 0'-0.0000"
tmp_hole_perimetro[10][52] = 0'-0.0000"
tmp_hole_perimetro[10][53] = 0'-0.0000"
tmp_hole_perimetro[10][54] = 0'-0.0000"
tmp_hole_perimetro[10][55] = 0'-0.0000"
tmp_hole_perimetro[10][56] = 0'-0.0000"
tmp_hole_perimetro[10][57] = 0'-0.0000"
tmp_hole_perimetro[10][58] = 0'-0.0000"
tmp_hole_perimetro[10][59] = 0'-0.0000"
tmp_hole_perimetro[10][60] = 0'-0.0000"
tmp_hole_perimetro[10][61] = 0'-0.0000"
tmp_hole_perimetro[10][62] = 0'-0.0000"
tmp_hole_perimetro[10][63] = 0'-0.0000"
tmp_hole_perimetro[10][64] = 0'-0.0000"
tmp_hole_perimetro[10][65] = 0'-0.0000"
tmp_hole_perimetro[10][66] = 0'-0.0000"
tmp_hole_perimetro[10][67] = 0'-0.0000"
tmp_hole_perimetro[10][68] = 0'-0.0000"
tmp_hole_perimetro[10][69] = 0'-0.0000"
tmp_hole_perimetro[10][70] = 0'-0.0000"
tmp_hole_perimetro[10][71] = 0'-0.0000"
tmp_hole_perimetro[10][72] = 0'-0.0000"
tmp_hole_perimetro[10][73] = 0'-0.0000"
tmp_hole_perimetro[10][74] = 0'-0.0000"
tmp_hole_perimetro[10][75] = 0'-0.0000"
tmp_hole_perimetro[10][76] = 0'-0.0000"
tmp_hole_perimetro[10][77] = 0'-0.0000"
tmp_hole_perimetro[10][78] = 0'-0.0000"
tmp_hole_perimetro[10][79] = 0'-0.0000"
tmp_hole_perimetro[10][80] = 0'-0.0000"
tmp_hole_perimetro[11][1] = 0'-0.0000"
tmp_hole_perimetro[11][2] = 0'-0.0000"
tmp_hole_perimetro[11][3] = 0'-0.0000"
tmp_hole_perimetro[11][4] = 0'-0.0000"
tmp_hole_perimetro[11][5] = 0'-0.0000"
tmp_hole_perimetro[11][6] = 0'-0.0000"
tmp_hole_perimetro[11][7] = 0'-0.0000"
tmp_hole_perimetro[11][8] = 0'-0.0000"
tmp_hole_perimetro[11][9] = 0'-0.0000"
tmp_hole_perimetro[11][10] = 0'-0.0000"
tmp_hole_perimetro[11][11] = 0'-0.0000"
tmp_hole_perimetro[11][12] = 0'-0.0000"
tmp_hole_perimetro[11][13] = 0'-0.0000"
tmp_hole_perimetro[11][14] = 0'-0.0000"
tmp_hole_perimetro[11][15] = 0'-0.0000"
tmp_hole_perimetro[11][16] = 0'-0.0000"
tmp_hole_perimetro[11][17] = 0'-0.0000"
tmp_hole_perimetro[11][18] = 0'-0.0000"
tmp_hole_perimetro[11][19] = 0'-0.0000"
tmp_hole_perimetro[11][20] = 0'-0.0000"
tmp_hole_perimetro[11][21] = 0'-0.0000"
tmp_hole_perimetro[11][22] = 0'-0.0000"
tmp_hole_perimetro[11][23] = 0'-0.0000"
tmp_hole_perimetro[11][24] = 0'-0.0000"
tmp_hole_perimetro[11][25] = 0'-0.0000"
tmp_hole_perimetro[11][26] = 0'-0.0000"
tmp_hole_perimetro[11][27] = 0'-0.0000"
tmp_hole_perimetro[11][28] = 0'-0.0000"
tmp_hole_perimetro[11][29] = 0'-0.0000"
tmp_hole_perimetro[11][30] = 0'-0.0000"
tmp_hole_perimetro[11][31] = 0'-0.0000"
tmp_hole_perimetro[11][32] = 0'-0.0000"
tmp_hole_perimetro[11][33] = 0'-0.0000"
tmp_hole_perimetro[11][34] = 0'-0.0000"
tmp_hole_perimetro[11][35] = 0'-0.0000"
tmp_hole_perimetro[11][36] = 0'-0.0000"
tmp_hole_perimetro[11][37] = 0'-0.0000"
tmp_hole_perimetro[11][38] = 0'-0.0000"
tmp_hole_perimetro[11][39] = 0'-0.0000"
tmp_hole_perimetro[11][40] = 0'-0.0000"
tmp_hole_perimetro[11][41] = 0'-0.0000"
tmp_hole_perimetro[11][42] = 0'-0.0000"
tmp_hole_perimetro[11][43] = 0'-0.0000"
tmp_hole_perimetro[11][44] = 0'-0.0000"
tmp_hole_perimetro[11][45] = 0'-0.0000"
tmp_hole_perimetro[11][46] = 0'-0.0000"
tmp_hole_perimetro[11][47] = 0'-0.0000"
tmp_hole_perimetro[11][48] = 0'-0.0000"
tmp_hole_perimetro[11][49] = 0'-0.0000"
tmp_hole_perimetro[11][50] = 0'-0.0000"
tmp_hole_perimetro[11][51] = 0'-0.0000"
tmp_hole_perimetro[11][52] = 0'-0.0000"
tmp_hole_perimetro[11][53] = 0'-0.0000"
tmp_hole_perimetro[11][54] = 0'-0.0000"
tmp_hole_perimetro[11][55] = 0'-0.0000"
tmp_hole_perimetro[11][56] = 0'-0.0000"
tmp_hole_perimetro[11][57] = 0'-0.0000"
tmp_hole_perimetro[11][58] = 0'-0.0000"
tmp_hole_perimetro[11][59] = 0'-0.0000"
tmp_hole_perimetro[11][60] = 0'-0.0000"
tmp_hole_perimetro[11][61] = 0'-0.0000"
tmp_hole_perimetro[11][62] = 0'-0.0000"
tmp_hole_perimetro[11][63] = 0'-0.0000"
tmp_hole_perimetro[11][64] = 0'-0.0000"
tmp_hole_perimetro[11][65] = 0'-0.0000"
tmp_hole_perimetro[11][66] = 0'-0.0000"
tmp_hole_perimetro[11][67] = 0'-0.0000"
tmp_hole_perimetro[11][68] = 0'-0.0000"
tmp_hole_perimetro[11][69] = 0'-0.0000"
tmp_hole_perimetro[11][70] = 0'-0.0000"
tmp_hole_perimetro[11][71] = 0'-0.0000"
tmp_hole_perimetro[11][72] = 0'-0.0000"
tmp_hole_perimetro[11][73] = 0'-0.0000"
tmp_hole_perimetro[11][74] = 0'-0.0000"
tmp_hole_perimetro[11][75] = 0'-0.0000"
tmp_hole_perimetro[11][76] = 0'-0.0000"
tmp_hole_perimetro[11][77] = 0'-0.0000"
tmp_hole_perimetro[11][78] = 0'-0.0000"
tmp_hole_perimetro[11][79] = 0'-0.0000"
tmp_hole_perimetro[11][80] = 0'-0.0000"
tmp_hole_perimetro[12][1] = 0'-0.0000"
tmp_hole_perimetro[12][2] = 0'-0.0000"
tmp_hole_perimetro[12][3] = 0'-0.0000"
tmp_hole_perimetro[12][4] = 0'-0.0000"
tmp_hole_perimetro[12][5] = 0'-0.0000"
tmp_hole_perimetro[12][6] = 0'-0.0000"
tmp_hole_perimetro[12][7] = 0'-0.0000"
tmp_hole_perimetro[12][8] = 0'-0.0000"
tmp_hole_perimetro[12][9] = 0'-0.0000"
tmp_hole_perimetro[12][10] = 0'-0.0000"
tmp_hole_perimetro[12][11] = 0'-0.0000"
tmp_hole_perimetro[12][12] = 0'-0.0000"
tmp_hole_perimetro[12][13] = 0'-0.0000"
tmp_hole_perimetro[12][14] = 0'-0.0000"
tmp_hole_perimetro[12][15] = 0'-0.0000"
tmp_hole_perimetro[12][16] = 0'-0.0000"
tmp_hole_perimetro[12][17] = 0'-0.0000"
tmp_hole_perimetro[12][18] = 0'-0.0000"
tmp_hole_perimetro[12][19] = 0'-0.0000"
tmp_hole_perimetro[12][20] = 0'-0.0000"
tmp_hole_perimetro[12][21] = 0'-0.0000"
tmp_hole_perimetro[12][22] = 0'-0.0000"
tmp_hole_perimetro[12][23] = 0'-0.0000"
tmp_hole_perimetro[12][24] = 0'-0.0000"
tmp_hole_perimetro[12][25] = 0'-0.0000"
tmp_hole_perimetro[12][26] = 0'-0.0000"
tmp_hole_perimetro[12][27] = 0'-0.0000"
tmp_hole_perimetro[12][28] = 0'-0.0000"
tmp_hole_perimetro[12][29] = 0'-0.0000"
tmp_hole_perimetro[12][30] = 0'-0.0000"
tmp_hole_perimetro[12][31] = 0'-0.0000"
tmp_hole_perimetro[12][32] = 0'-0.0000"
tmp_hole_perimetro[12][33] = 0'-0.0000"
tmp_hole_perimetro[12][34] = 0'-0.0000"
tmp_hole_perimetro[12][35] = 0'-0.0000"
tmp_hole_perimetro[12][36] = 0'-0.0000"
tmp_hole_perimetro[12][37] = 0'-0.0000"
tmp_hole_perimetro[12][38] = 0'-0.0000"
tmp_hole_perimetro[12][39] = 0'-0.0000"
tmp_hole_perimetro[12][40] = 0'-0.0000"
tmp_hole_perimetro[12][41] = 0'-0.0000"
tmp_hole_perimetro[12][42] = 0'-0.0000"
tmp_hole_perimetro[12][43] = 0'-0.0000"
tmp_hole_perimetro[12][44] = 0'-0.0000"
tmp_hole_perimetro[12][45] = 0'-0.0000"
tmp_hole_perimetro[12][46] = 0'-0.0000"
tmp_hole_perimetro[12][47] = 0'-0.0000"
tmp_hole_perimetro[12][48] = 0'-0.0000"
tmp_hole_perimetro[12][49] = 0'-0.0000"
tmp_hole_perimetro[12][50] = 0'-0.0000"
tmp_hole_perimetro[12][51] = 0'-0.0000"
tmp_hole_perimetro[12][52] = 0'-0.0000"
tmp_hole_perimetro[12][53] = 0'-0.0000"
tmp_hole_perimetro[12][54] = 0'-0.0000"
tmp_hole_perimetro[12][55] = 0'-0.0000"
tmp_hole_perimetro[12][56] = 0'-0.0000"
tmp_hole_perimetro[12][57] = 0'-0.0000"
tmp_hole_perimetro[12][58] = 0'-0.0000"
tmp_hole_perimetro[12][59] = 0'-0.0000"
tmp_hole_perimetro[12][60] = 0'-0.0000"
tmp_hole_perimetro[12][61] = 0'-0.0000"
tmp_hole_perimetro[12][62] = 0'-0.0000"
tmp_hole_perimetro[12][63] = 0'-0.0000"
tmp_hole_perimetro[12][64] = 0'-0.0000"
tmp_hole_perimetro[12][65] = 0'-0.0000"
tmp_hole_perimetro[12][66] = 0'-0.0000"
tmp_hole_perimetro[12][67] = 0'-0.0000"
tmp_hole_perimetro[12][68] = 0'-0.0000"
tmp_hole_perimetro[12][69] = 0'-0.0000"
tmp_hole_perimetro[12][70] = 0'-0.0000"
tmp_hole_perimetro[12][71] = 0'-0.0000"
tmp_hole_perimetro[12][72] = 0'-0.0000"
tmp_hole_perimetro[12][73] = 0'-0.0000"
tmp_hole_perimetro[12][74] = 0'-0.0000"
tmp_hole_perimetro[12][75] = 0'-0.0000"
tmp_hole_perimetro[12][76] = 0'-0.0000"
tmp_hole_perimetro[12][77] = 0'-0.0000"
tmp_hole_perimetro[12][78] = 0'-0.0000"
tmp_hole_perimetro[12][79] = 0'-0.0000"
tmp_hole_perimetro[12][80] = 0'-0.0000"
tmp_hole_perimetro[13][1] = 0'-0.0000"
tmp_hole_perimetro[13][2] = 0'-0.0000"
tmp_hole_perimetro[13][3] = 0'-0.0000"
tmp_hole_perimetro[13][4] = 0'-0.0000"
tmp_hole_perimetro[13][5] = 0'-0.0000"
tmp_hole_perimetro[13][6] = 0'-0.0000"
tmp_hole_perimetro[13][7] = 0'-0.0000"
tmp_hole_perimetro[13][8] = 0'-0.0000"
tmp_hole_perimetro[13][9] = 0'-0.0000"
tmp_hole_perimetro[13][10] = 0'-0.0000"
tmp_hole_perimetro[13][11] = 0'-0.0000"
tmp_hole_perimetro[13][12] = 0'-0.0000"
tmp_hole_perimetro[13][13] = 0'-0.0000"
tmp_hole_perimetro[13][14] = 0'-0.0000"
tmp_hole_perimetro[13][15] = 0'-0.0000"
tmp_hole_perimetro[13][16] = 0'-0.0000"
tmp_hole_perimetro[13][17] = 0'-0.0000"
tmp_hole_perimetro[13][18] = 0'-0.0000"
tmp_hole_perimetro[13][19] = 0'-0.0000"
tmp_hole_perimetro[13][20] = 0'-0.0000"
tmp_hole_perimetro[13][21] = 0'-0.0000"
tmp_hole_perimetro[13][22] = 0'-0.0000"
tmp_hole_perimetro[13][23] = 0'-0.0000"
tmp_hole_perimetro[13][24] = 0'-0.0000"
tmp_hole_perimetro[13][25] = 0'-0.0000"
tmp_hole_perimetro[13][26] = 0'-0.0000"
tmp_hole_perimetro[13][27] = 0'-0.0000"
tmp_hole_perimetro[13][28] = 0'-0.0000"
tmp_hole_perimetro[13][29] = 0'-0.0000"
tmp_hole_perimetro[13][30] = 0'-0.0000"
tmp_hole_perimetro[13][31] = 0'-0.0000"
tmp_hole_perimetro[13][32] = 0'-0.0000"
tmp_hole_perimetro[13][33] = 0'-0.0000"
tmp_hole_perimetro[13][34] = 0'-0.0000"
tmp_hole_perimetro[13][35] = 0'-0.0000"
tmp_hole_perimetro[13][36] = 0'-0.0000"
tmp_hole_perimetro[13][37] = 0'-0.0000"
tmp_hole_perimetro[13][38] = 0'-0.0000"
tmp_hole_perimetro[13][39] = 0'-0.0000"
tmp_hole_perimetro[13][40] = 0'-0.0000"
tmp_hole_perimetro[13][41] = 0'-0.0000"
tmp_hole_perimetro[13][42] = 0'-0.0000"
tmp_hole_perimetro[13][43] = 0'-0.0000"
tmp_hole_perimetro[13][44] = 0'-0.0000"
tmp_hole_perimetro[13][45] = 0'-0.0000"
tmp_hole_perimetro[13][46] = 0'-0.0000"
tmp_hole_perimetro[13][47] = 0'-0.0000"
tmp_hole_perimetro[13][48] = 0'-0.0000"
tmp_hole_perimetro[13][49] = 0'-0.0000"
tmp_hole_perimetro[13][50] = 0'-0.0000"
tmp_hole_perimetro[13][51] = 0'-0.0000"
tmp_hole_perimetro[13][52] = 0'-0.0000"
tmp_hole_perimetro[13][53] = 0'-0.0000"
tmp_hole_perimetro[13][54] = 0'-0.0000"
tmp_hole_perimetro[13][55] = 0'-0.0000"
tmp_hole_perimetro[13][56] = 0'-0.0000"
tmp_hole_perimetro[13][57] = 0'-0.0000"
tmp_hole_perimetro[13][58] = 0'-0.0000"
tmp_hole_perimetro[13][59] = 0'-0.0000"
tmp_hole_perimetro[13][60] = 0'-0.0000"
tmp_hole_perimetro[13][61] = 0'-0.0000"
tmp_hole_perimetro[13][62] = 0'-0.0000"
tmp_hole_perimetro[13][63] = 0'-0.0000"
tmp_hole_perimetro[13][64] = 0'-0.0000"
tmp_hole_perimetro[13][65] = 0'-0.0000"
tmp_hole_perimetro[13][66] = 0'-0.0000"
tmp_hole_perimetro[13][67] = 0'-0.0000"
tmp_hole_perimetro[13][68] = 0'-0.0000"
tmp_hole_perimetro[13][69] = 0'-0.0000"
tmp_hole_perimetro[13][70] = 0'-0.0000"
tmp_hole_perimetro[13][71] = 0'-0.0000"
tmp_hole_perimetro[13][72] = 0'-0.0000"
tmp_hole_perimetro[13][73] = 0'-0.0000"
tmp_hole_perimetro[13][74] = 0'-0.0000"
tmp_hole_perimetro[13][75] = 0'-0.0000"
tmp_hole_perimetro[13][76] = 0'-0.0000"
tmp_hole_perimetro[13][77] = 0'-0.0000"
tmp_hole_perimetro[13][78] = 0'-0.0000"
tmp_hole_perimetro[13][79] = 0'-0.0000"
tmp_hole_perimetro[13][80] = 0'-0.0000"
tmp_hole_perimetro[14][1] = 0'-0.0000"
tmp_hole_perimetro[14][2] = 0'-0.0000"
tmp_hole_perimetro[14][3] = 0'-0.0000"
tmp_hole_perimetro[14][4] = 0'-0.0000"
tmp_hole_perimetro[14][5] = 0'-0.0000"
tmp_hole_perimetro[14][6] = 0'-0.0000"
tmp_hole_perimetro[14][7] = 0'-0.0000"
tmp_hole_perimetro[14][8] = 0'-0.0000"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-10 04:26 AM
Good Grief, what a mess, I can't make sense of it.
You say, "4: Yes. Is there a difference? Archicad is a surface modeler, not a solid modeler. "
I have heard this said before.
I wonder what you mean.
All cad images are illusions. Nothing is really solid.
Would you mind elucidating a little ?
What is a solid modeler vs a surface modeler ?
Thanks,
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-10 04:43 AM
Archicad merely makes connect-the-dots flat surfaces that are voids internally. Some other modelers, I am led to understand, pretend the inside is a mass. When you drive the camera in there, it is impossible to see.
Also, a solid is "internally connected." It has rationality behaving as a physical plane or volume. When you bend a solid, it distorts as an object, not as a series of connected nodes in space that can do anything. For instance, my studio is in the process of aquiring CATIA because we are planning a series of distorted sheet metal sculptures and want to control the curvature derived from flat cut sheets. You simply cannot do this in Archicad because the relationships aren't "solid."
I just did my first curved sheet metal project - one that we are installing in Denver in two weeks. The way I did it in Archicad was to lay out the panels and print them. Then we cut the panels out and built a model to see how they went together. No way to accurately loft the flat panels in the application..... got to get those bolt holes lining up.
BTW: it is also absurd that to send instructions to the waterjet guy I had to make Adobe Illustrator files, if you can believe it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-10 05:15 AM
Thank you very much for the explanation.
You seem to be saying that solid modeling software calculates
stresses and shows the consequences as deformations as
though the element was made of a material with physical characteristics
Surface modeling software makes surfaces like a net made from
sticks connected by ball and socket hinges that if made physically
would collapse in a heap. Not helpful if you want to build something
that won't fall down.
Thank you very much Dwight.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-10 05:59 AM
Take the roof tool… please!
When the roof slope changes, the roof length changes. Very tidy for architects planning roofs (British spelling: rooves) but lousy when you need an inclined plane of a reliable size.
Yes, we have objects that do that, but try and twist it and the relationshipps fail.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-09-12 02:59 AM
Must get ArchiForma.....
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
