Problem with container
Everything was working fine until I had my G5 tower stolen. So I had to reinstalled everything. I did have a back up so that was great. Now I'm on the 24" Imac with the latest operating system (Mac OSx 10.5.4) and I'm trying to create a container. I loaded all the libraries that I want, no problems. But as soon as I create a container out of the same list of libraries I just loaded, I get this error message. Does any one have any ideas what this mean ?
So I have to leave the list of libraries as individual ones. The container is supposed to be faster and that is why I'm trying to make one.
The details of your situation are a bit unclear to me, but what you are seeing appears to be a CADimage data file that thinks is open for read/write operations (perhaps it is, or perhaps it just hasn't been properly closed).
I don't bother with making container files since I don't find the speed difference to be significant. When I use the GS supplied and 3rd party libraries I leave them as intact containers just to ensure that they remain unchanged, but office standard and custom project libraries I just keep as loose parts.
If what you are trying to do is combine all your libraries into a single container I recommend against this. It will take more time and cause more trouble than the small speed improvements are worth.
Mathew,
I was under the impress that if you have different libraries, that you should put them all into one container and only load that one item. I'm not sure I really see the speed difference either between loading 10 different libraries versus loading one container with those same libraries in it.
So you think that is a Cadimage issue ? I'll ask them about that. I do have the Cadimage Accessories Tool.
I don't know if it is even an issue at all. The message does appear to be related to a CADimage data file but it is not clear to me that there is a problem.
Again, I recommend that you don't bother with making a single container file of all your libraries. I believe it is a waste of time and has the potential to cause problems in operations and maintenance.
