Problems with depository object " Omuncolo "
So I've downloaded the 3D person named Omuncolo and I want to change the dimensions of it but when I enter a different dimension from the default, the actual 3D ( or 2d ) figure does not change. I've sent a PM to the creator but they haven't replied. I was just wondering why the object doesn't respond to changed made in the settings dialog.
Thank You
1 REPLY 1
It may be coded to a fixed size. (I usually lock out the size parameters when I do this.) There are many things for which size adjustments make no sense like some furniture and most plumbing fixtures. Size adjustment (within limits) would make sense for a generic human figure but I guess the author chose not to include that option.
