Learn more
Miquel Garcia
Problems with special characters
We are developing a project in Hungary from Spain for a spanish company, and all the plans must be in both (spanish and hungarian) languages
I'm working on an text object that permits me to have the two languages together and control if there are texts without translation, but I have found a problem with some special characters of the hungarian alfabet.
1.- I can write it in ArchiCAD with the text tool using the character palette of the Mac, but I can't access this palette from the object dialog box
2.- If I write it with the text tool and copy/paste these characters in my object it changes to a different ones.
An example of this is the LATIN SMALL LETTER O WITH DOUBLE ACUTE ő
I have tried to paste it in the 2D Script and the result is the same. I'm sure that in Hungary nobody has this problem, but probably they work with hungarian keyboards.
Is there any solution?
Miquel
Capella & Garcia Arquitectura
AC18 - AC21, iMac 27" 3.1 Ghz Intel Core i7, 16GB Ram, OSX 10.13.1
1 Reply 1
Set the proper "font script code" (search for it on the archicadwiki)
Best Regards,
Piotr
