Project Info Custom Keywords
goal is to have my Title block object get different "drawn by" for each Department. created custom keywords in project info for each Arch, MEP, Interiors, and based on pull out menu in object parameters looking to call each one separately.
Can't get the part to read the Keywords from project info.
What tells part to get data from Project info?
Hello,
Keyword between brackets should work
<ARCHITECT>
less than/ greater than Brackets do the trick.
thanksjavascript:emoticon('8)')
