Putting a range on set values
JGoode
I'd like to be able to put a range on a parameter that has set values.
My values are these:
values "upright_height" 0.71, 1, 1.22, 1.6, 1.98, 2.4
But I want to be able to add a max range of something that might be less than 2.4 so ideally my values would remove the 2.4, how can I add this?
Thanks
ArchiCAD 27
Windows 10
7 REPLIES 7
Not quite sure I follow what you want but you can add a RANGE option to your VALUE list.
See the example in the GDL manual.
JGoode
For example I might set ceiling height to 2.2m therefore having my upright height at 2.4 doesn't work so I'd like to remove that from my values list. So it was automatically only give me the options of 0.71, 1, 1.22, 1.6, 1.98 and remove the 2.4.
I hope this helps to explain what I'm trying to achieve a bit clearer.
Thanks
ArchiCAD 27
Windows 10
Erwin Edel
Sounds like you need a few IF ... THEN statements to check for the range and then define values.
This would work if ceiling height is a parameter in your object.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
JGoode
I knew it would be possible with IF's but I was curious as to if there was a simple way of doing it.
Thanks
ArchiCAD 27
Windows 10
You can use get() in Values* command (without RANGE)...
Piotr
JGoode
I haven't ever used this and the reference guide doesn't really explain how to use it. Do you have any very basic examples of how I might use it?
Thanks very much
ArchiCAD 27
Windows 10
Jochen Suehlo
PUT 0.71, 1, 1.22, 1.6, 1.98
IF ch >= 2.2 THEN PUT 2.4
VALUES "upright_height" GET(NSP)
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
