Quantities from GDL objects
I made a custom object that has 2 different parts to it. I would like to be able to have archicad get the quantities of each separate.
I am looking for volume from each part. Right now it groups them both together and gives me a total volume for both parts.
2 REPLIES 2
TomWaltz
You would need to manually calculate them inside the object's Master script then use the "PARAMETERS" command to send them over the the object's parameter list in order to get them to show up in a schedule.
Tom Waltz
Thanks.
The trouble I'm having now is when I multiple all the numbers up to get volume it gives me the incorrect value.
L*W*H = X
Any suggestions???
