RAMPS - proper floor plan above Home Story (NOT SOLVED)
Hello!
Since the new Stair tool we've been forced to use the Ramp Object for creating ramps.
Obviously the Break line and the Dash-Dot graphics are not properly representing the Ramp in the stories above the home one.
Is there a way to set a different view parameters for the "Above Story"?
2 Replies 2
Have you tried this method of creating Ramps with the Stair Tool?:
https://archicad-talk.graphisoft.com/viewtopic.php?p=268244#p268244
Yes, doesn't quite work in 2D. Either there's an obvious solution that I'm missing or somebody at Graphisoft completely messed up.
I can use 2 ramps with different view options, but this is a compromise and the 3D gets glitchy.
