Raising the height of a door?
Is it possible to raise the height of a door if two floors are classed under one story. Or if not how do you make the second floor a new story?
2 Replies 2
Aussie John
Make a new storey in Storey settings and cut and paste from the original storey element to the other storey. Once on the other storey you will need to reset the height above storey as it will have moved by the distance as set in the Storey settings for elevation
Cheers John
[/size]
Thanks John i'll give that a try.
