Ramp Object Text Not Showing
Hi, I'm using the object tool to place a straight ramp. And, I would like for the text to display at 9 pts or 6". However, the text does not show using the correct size of 9pts. As you can see in the picture below I am forced to use the font size of .43; which is too small. If I use anything larger than that the text disappears. How can I have the text display properly at the correct size of 9pts (6")?
0 Replies 0
